01-28-2019, 06:06 PM | #1 |
Heavy duty Y block exhaust valve cap
Hi guys!
My Y block is a heavy duty edition (truck motor) and the exhaust valves are larger than the intakes and are sodium filled. Stupidly, I lost one of these valve lash caps while replacing the valve seals. Any leads on replacement? The valve diameter is 0.434” (as seen online and the parts guy at Summit Racing told me) and I’m sure other Ford engines used these caps. Anyone have a link for a part number or know what other engines used these caps? Not having much luck finding aftermarket or eBay when searching for Y block. Thanks in advance. Sent from my iPhone using Tapatalk |
01-28-2019, 06:23 PM | #2 |
Re: Heavy duty Y block exhaust valve cap
Maybe find a "Y" block rebuilder near where you live. They may have a few spare parts or can tell you where to find the part. Are you sure about that .434 stem Diameter? Seems awfully large to me but then I've never been inside a "Y" block.
01-28-2019, 08:36 PM | #3 |
Contact Ted Eaton in Texas. he rebuilds Y's and should have some around
Ted Eaton (254)857-3339 [email protected] 1060 Wolf Creek Rd., Lorena Tx, 76655 Or John Mummert (619) 596-0312 faxes: call first. Due to the ridiculous number of junk faxes I can no longer leave it on. E-MAIL: [email protected]
01-28-2019, 09:24 PM | #4 |
Thanks, I sent Eaton an email!
01-29-2019, 12:50 AM | #5 | |
These engines also had steel cranks, and shorter rods for some reason. Therefore they used special pistons with the pin lower in the piston. |
01-29-2019, 06:56 AM | #6 |
01-29-2019, 07:08 AM | #7 |
Thanks guys, Ted has one and will be sending it out. I appreciate the help!
Guaranteed when I pull the truck out it will fall from wherever it is hiding lol Sent from my iPhone using Tapatalk |
01-29-2019, 07:13 AM | #8 |
I also lost one on a 332 Y = Precision Engine right down my street stocks those. He said
common on race engines. |
01-29-2019, 11:18 AM | #9 |
its to bad ford didnt use these on all y block valves.they are hard and dont wear.valves are easy to set.
01-29-2019, 12:01 PM | #10 |
01-29-2019, 12:14 PM | #11 |
01-29-2019, 12:51 PM | #12 |
I never saw a failure on any of those heavy duty heads except an occasional seat coming loose
01-29-2019, 06:07 PM | #13 |
The problem with any of Ford's sodium filled valves, they would occasionally break. I have seen several on the FT series and 1 on a Y block
01-29-2019, 06:20 PM | #14 |
we seem to have gotten lost we were talking about caps not sodium valves.that was what i was talking about at any rate.
01-29-2019, 11:52 PM | #15 |
02-07-2019, 08:43 PM | #16 | |
Hi Darrell, Ted sent me one but it is too small! If you have the right size can you drop one in the mail for me? PM me for the address. Sent from my iPhone using Tapatalk |
02-08-2019, 03:17 AM | #17 | |
The sodium after a period will become caustic and attack the inner valve stem. The cap protects the valve stem (which is hollow and weak) from being beat to death by the rocker arm. Same method used on the FE 427 MR.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
02-10-2019, 07:45 PM | #18 |
I ponied up and bought one from Mummert. $20 min order.
02-10-2019, 08:28 PM | #19 |
I was going to post a PN but thought you were covered - -B5Q 6550-A- You sometimes come across them on EvilBay.
