Old 04-11-2020, 06:54 AM   #1
veggie
veggie's Avatar
Send a message via AIM to veggie Send a message via Yahoo to veggie
Default Not running
hi Barners
Can you help me? I have 1930 Model AThat runs for about 10 seconds. I replaced the carburetor with a know good one, new intake and exhaust manifolds and still does not run. What I am looking for is someone that can help me. I live in the South Jersey area near Toms River. I will pay for someone to help me.
veggie is offline   Reply With Quote
Old 04-11-2020, 06:58 AM   #2
Ray64
Ray64's Avatar
Default Re: Not running
Take the gas line from the carb and check for a full flow Acts like fuel starvation
Ray64 is offline   Reply With Quote
Old 04-11-2020, 07:00 AM   #3
KGBnut
KGBnut's Avatar
Could be as simple as gas cap vent. Try running it with the gas cap off.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 04-11-2020, 08:02 AM   #4
Big hammer
GAV opened 1 turn ? Pull the advance lever down 2 clicks when it starts !
get a bigger hammer tap done
Old 04-11-2020, 09:34 AM   #5
veggie
veggie's Avatar
Iwill try
THANKS
Old 04-11-2020, 09:47 AM   #6
Gary WA
Gary WA's Avatar
Originally Posted by veggie View Post
hi Barners
Local club Members in area???? any rust in glass sediment bulb?or cast iron one clean out! Rust in tank valve?
www.whidbeymodelaclub.com
Old 04-11-2020, 09:50 AM   #7
fuzes45
Remove plug from bottom of carb, not bolt that holes the halfs togeather and see
if gas flows thru carb.
Bob
fuzes45 is offline   Reply With Quote
Old 04-11-2020, 09:53 AM   #8
jimvette59
jimvette59's Avatar
Gas line in to far into the carb. It should only stick out 1/4" past the ferrel.
jimvette59 is offline   Reply With Quote
Old 04-11-2020, 09:54 AM   #9
30 Closed Cab PU
remove a spark plug lead on the spark plug. Place teh free end about 1/4 inch from teh plug terminal. turn car over and see what happens with the spark. This may tell you if it is ignition related.
Old 04-11-2020, 10:04 AM   #10
rocket1
going back to square one was it running good before you worked on it?
rocket1 is offline   Reply With Quote
Old 04-11-2020, 11:58 AM   #11
veggie
veggie's Avatar
The car stopped while driving it. I had to tow it home. This happened last fall.
Thanks for your interest.
Old 04-11-2020, 03:19 PM   #12
Mulletwagon
Mulletwagon's Avatar
Maybe the pencil filter on the shut off valve is clogged. Disconnect the fuel line at the carb and ensure there is flow. If flow is good investigate electrical. Begin by checking for a spark at the plugs during the no-start. Should be something simple to track down. Good Luck - and please share the fix.
Mulletwagon is offline   Reply With Quote
Old 04-11-2020, 05:12 PM   #13
burner31
burner31's Avatar
So it runs for 10 seconds and dies? Let it sit awhile and will it run for 10 seconds and die again/,,,fuel
Keith
Shawnee OK
'31 SW 160-B
Old 04-11-2020, 05:21 PM   #14
Purdy Swoft
Purdy Swoft's Avatar
It could be the condenser .
Old 04-11-2020, 05:41 PM   #15
Charlie Stephens
Ten seconds sounds like it is using up the fuel in the carburetor bowl and something is restricting the flow to refill it fast enough to continue running.
Charlie Stephens
Old 04-11-2020, 06:30 PM   #16
Sunnybrook Farm
Sunnybrook Farm's Avatar
I would unscrew the gas line from the carb then turn on the fuel and see if fuel runs out. If it does then it is something to do with the float of the float valve sticking. If you have a spare condenser then change it to rule that out, I had one mess up but it ran for a long time before flaking out but you could have a strange one. Sorry to give you a bunch of different things but I just start eliminating things before swapping out a lot of parts but I would have swapped to a spare carb if one was available.
Sunnybrook Farm is offline   Reply With Quote
Old 04-11-2020, 06:33 PM   #17
Synchro909
Synchro909's Avatar
I also suspect a fuel blockage. The first test I'd do is as Fuzes45 says in post #7. It could be a sticky float valve, crap in a fuel line (including rust) or clogged sediment bowl. I think it would take more than 10 seconds for a blocked vent in the fuel cap to stop the engine. I had it once and drove miles before it started showed up.
Please let us know what you do to fix it.
Old 04-12-2020, 09:06 AM   #18
rotorwrench
rotorwrench's Avatar
I'm one for bad condenser too. Get a couple of blow proof condensers to keep a spare. They are a lot easier to change than the carburetor. The coil could also have a problem too but I replace the easiest suspected thing first then move on from there. That is a basic principle in troubleshooting. Coils can work while cold but the circuit will open on one with a bad winding after it heats up and expands.
Old 04-21-2020, 07:43 AM   #19
dsarge390
dsarge390's Avatar
PM Sent
dsarge390 is offline   Reply With Quote
Old 04-21-2020, 11:20 PM   #20
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
What happened?? We would like to know if you solved the problem?
