Old 05-26-2019, 02:03 PM   #21
Railcarmover
Default Re: Spark-Lever Posistion
The phillips spark advance (nurex) works on the same principal,and is effective.I prefer the function in the distributor,it makes any maintenance required easier.
Railcarmover is offline   Reply With Quote
Old 05-27-2019, 05:46 PM   #22
maako
maako's Avatar
I put this on the wrong post.
maako is offline   Reply With Quote
Old 05-27-2019, 06:30 PM   #23
Ruth
How so. The Nu-Rex operates on a Gyro. There is no "maintenance" unless it breaks, which i doubt will happen. It is bathed in oil being splashed around the valve chamber so no need to lube.
Old 05-27-2019, 07:04 PM   #24
Terry, NJ
Terry, NJ's Avatar
50% of the advance will make my engine over heat!
Terry
Terry, NJ is offline   Reply With Quote
Old 05-27-2019, 08:21 PM   #25
Railcarmover
How so? You dont have to tear the valve cover off and remove the distributor if you have a problem..both systems work on centrifugal force,both work well,good luck with your phillips.
Old 05-28-2019, 08:24 AM   #26
Patrick L.
Patrick L.'s Avatar
And here I thought part of the fun of owning these old monsters was getting used to how to operate them.
Old 05-28-2019, 10:21 AM   #27
100IH
The mechanical advances do not respond to load unless they also have a vacuum diaphragm to retard timing when the vacuum drops relative to load.
100IH is offline   Reply With Quote
Old 05-28-2019, 11:11 AM   #28
Ruth
You are correct. That is why I set my initial timing retarded so I can manually retard the timing when going up a steep grade. With the Nu-Rex/Phillips you retain your timing lever.
Old 05-28-2019, 07:02 PM   #29
eagle
eagle's Avatar
It is such a simple thing to adjust the spark as needed. A little know-how and some common sense is all that's needed. I'd say if someone can't figure it out, they should stick with a Toyota.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Thread Tools
Display Modes
