04-22-2020, 07:43 PM | #1 |
1966 F100 rear axle shaft for 9 inch
Hello all. Looking for a good used axle for a 66 F100 9 inch rear. Was taking this rear apart and 1 axle is bent. Axle shaft is 28 spline, measures 30 " from flange to end of splines, 5x5.5 bolt pattern and bearing inside diameter is about 1 5/8. Rear is all stock. Thank you and stay safe.
Sent from my SM-G960U using Tapatalk |
04-30-2020, 08:06 AM | #2 |
Re: 1966 F100 rear axle shaft for 9 inch
