01-16-2018, 07:03 PM | #1 |
question; Valve,guide and clip?
When the guide and valve sit in I take it that it is just spring pressure against the horse shoe clip that holds it 'firm' in place? I was wondering if the horse shoe clip fit is 'loose' would there be any chance of the guide moving, say at high revs?
I have quite a few old clips and they do vary in thickness... Just a thought
"Came too close to dying to stop living now!" |
01-16-2018, 07:16 PM | #2 |
Re: question; Valve,guide and clip?
The valve spring does hold tension against the horse shoe clip. The only difference I think the thickness of the clip would make is to vary the installed height of the spring a little. A thin clip might let the guide rise up in the bore a little more.
01-16-2018, 08:39 PM | #3 |
I guess the only way for the guide to move would be a loose bore, weak spring or sticky valve...?
01-17-2018, 02:55 PM | #4 |
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
