12-23-2010, 09:30 PM | #1 |
identifying flat head engines
what are the visible differences between the flatheads from 49 thru 53?
i have 7 flatheads with headbolts and 8ba on the heads, what years are they? some have narrow fan belts and some have wide ones. |
12-23-2010, 10:27 PM | #2 |
Re: identifying flat head engines
Ford car heads from 1949-1951 had 8ba on them.
12-23-2010, 11:02 PM | #3 |
49 flatheads had wide fan belts; 50-51 narrow.
Highwinder 49 Ford Custom Club Coupe |
12-24-2010, 05:46 AM | #4 |
what about merc from ford outher than blue
12-24-2010, 07:08 AM | #5 |
We would like to see some pictures to give you a good answer. The later flatties (52-53) will have EAC, EBC, on the heads. The trucks usually have 8RT on the heads, and have a cast iron bell housing, and a large removable clean out on the oil pan. Picture would help, Chuck.
12-24-2010, 09:08 AM | #6 | |
12-24-2010, 09:25 AM | #7 |
Some may have aluminum timing covers and matching aluminum distributors. Some may have cast iron timing covers with matching "steel" distributers. I am not sure which years this applies to.
12-24-2010, 10:03 AM | #8 | |
I dig coal, which provides motivation for EVs. |
12-24-2010, 10:05 AM | #9 |
A truck engine has different exhaust manifolds. The crossover crosses under the oil pan.
12-24-2010, 11:45 AM | #10 |
Trucks have the early style water pump/engine mounting and usually wide belts till 53. Fords and 53 pick ups have the waterpump/engine mounts with the near 45 degree angle down towart the center of the engine. 1949 thru 51 Mercs have the water pump/engine mount arm that is mounted much higher on the pump. The 49 Mercs were wide belt type and the late 49 thru 51 types were narrow belt with the same basic pump type. The 52 thru 53 Mercs had same pump as Ford cars & 53 pickups all with narrow belts.
Ford cars had a center sump oil pan and the pick ups & trucks had the rear sump, some with cleanout, some without. The Merc thru 51 had rear sump with three studs on the bottom for the starter plate brace. 52 thru 53 Mercs were center sump same as Ford car. 8BA on ford car & pick up heads from 49 to late 51. Starting in 52 For trucks had 8RT heads unless replaced for service. 8CM on 49 thru early 51 Merc heads. 1CM on late 51 Merc heads then on to EAC for 52 thru 53 Mercs. EAB heads "the good ones for compression" on Ford cars from 52 thru 53. Some late F100 pick ups may have had the EAB heads as well but the bigger trucks all had the 8RT. I've seen more NOS 8RT heads than any of the others probably due to late manufacture of these for replacement parts. Many 8RT heads probably were stocked for longer by Ford dealerships since trucks usually stay in service longer than cars do. The only difference in the intake manifold was between Ford cars & trucks thru F6 with the Holley 8BA type carb. They are all still 3-bolt type. The Mercury and the big trucks above F6 had the 4-bolt carb base for the Holley 885 towering inferno carbs. There are several differences in front covers by casting features or material, ie aluminum or cast iron but I can't date them. Mercury got the slim shaft Holley Loadamatic distributors first but they were mixed & matched between all the others with the wide shaft housing units after a while. Kerby Last edited by rotorwrench; 12-24-2010 at 11:54 AM. |
12-24-2010, 12:31 PM | #11 |
Quick reference. I didn't write it, the engine builder that did my flathead did for me.
1932 to 1933 Main Bolts through to Valley 1932 to 1934 No Cam Bearings 1932 to 1934 36 Tooth Cam Gear 1932 to 1935 Babbit Mains 1932 to 1936 2.00" Main Journals 1932 to 1937 Water Pumps in Heads 1932 to 1937 Timing Gear Pressed On 1932 to 1938 Rod Housing Bores 2.200" 1932 to 1938 21 Stud Heads 1932 to 1938 1.937 Rod Bearing Width (Flanged) 1932 to 1940 Core Plugs in Oil Pan Rails 1932 to 1942 2.00 Rod Journals 1932 to 1945 3 1/16" Bore 1932 to 1945 No Rear Seal 1932 to 1945 Irregular Water Holes 1932 to 1945 One Oil Hole Per Rod Throw 1932 to 1948 2 Piece Valve Guides 1932 to 1948 Mushroom Valves 1932 to 1948 Integral Bellhousing 1935 to 1948 Main Studs 1935 to 1948 Oil Filler/Breather Tube 1935 to 1948 44 Tooth Cam Gear 1935 to 1948 3 Cam Bearings 1936 - 1937 Thick Wall Main Bearings 1937 to 1938 2.400" Main Bearings 1937 to 1948 Water Outlets in Center of Heads 1938 to 1948 Water Pumps in the Block 1938 to 1948 Timing Gear Bolted On 1939 to 1946 1.750" Rod Bearing Width (No Flange) 1939 to 1942 2.00" Rod Journals (1.750" Wide) 1939 to 1948 24 Head Studs 1939 to 1948 2.500" Main Journals 1941 to 1942 Raised Intake Mount (Not Proven) 1942 to 1948 Rod Housing Bores 2.360" 1942 to 1948 2.139" Rod Journals (1.750" Wide) 1942 to 1953 2.139" Rod Journals 1942 - 1945 WAR, No General Production 1946 to 1948 Triangle and 2 Round Water Holes 1946 to 1948 3 3/16" Bore 1946 to 1948 Rear Main Caps with Drain Tubes / No Seals 1946 to 1948 "59" Casting 1949 to 1953 "Shorty Oil Pump 1949 to 1953 2 Oil Holes Per Rod Throw 1949 to 1953 Individual Rod Bearings 1949 to 1953 2 Oil Holes in Rod Throws 1949 to 1953 Distributor Moved to Top Right 1949 to 1953 Bolt on Bellhousing 1949 to 1953 One Piece Valve Guides 1949 to 1953 Modern Style Vavles and Keepers 1950 to 1953 New Helical Gear Design Oil Pump Last edited by Tinker; 12-25-2010 at 11:20 AM. Reason: typo |
12-24-2010, 07:46 PM | #12 |
Hey, what about the 1954 models we got here in Australia??
Manuel in Oz |
12-24-2010, 09:14 PM | #13 |
Where is Lalter Valley? Is that in California, maybe up by Redding? Stopped for gas there one time, the guy says "Alberta? What state is that?" I said "Alberta is in Canada". He seemed dubious. "Your Northern neighbor?" I can tell he's thinking about who lives on his block. "Alberta is bigger than Texas and has more oil" Total disbelief at that. ..B.
12-25-2010, 09:18 AM | #14 |
No, "Alaska is bigger than Texas and has more oil".
Coming from an Ex Texan. |
12-25-2010, 11:20 AM | #15 |
I'm assuming it's a typo :]' Just a quick reference, add to it if you like.
Barlea, about 15yrs ago I went around work with a blank U.S. map and asked everyone to fill in the names of the states to settle an argument. 10% named 100%-90% of the states correct, 50% named about 60-70%, 40% named less then 50%. One person named two states. Florida and Georgia. Lived in Miami all his life. Most missed was the Dakotas and midwest states. |
12-25-2010, 02:20 PM | #16 |
what a wealth of info from a simple question.
i thank you all. merry christmas and a happy new year. trvguy PS. i accually have 12 flatheads in my shop. some old ones too. |
