04-09-2019, 02:49 PM | #1 |
Schrader tire gauge repair
Has anyone taken one of these gauges apart? I can unscrew the head and that is about it.
04-09-2019, 05:08 PM | #2 |
Re: Schrader tire gauge repair
Mine was frozen with rust so I left it in diesel for a couple of months. Finally managed to dismantle it, but don't have the spare parts to repair it.
04-09-2019, 09:07 PM | #3 |
What is inside?
04-09-2019, 10:03 PM | #4 |
04-10-2019, 08:40 AM | #5 |
I just replaced the o-ring and mine works just fine.
Dick |
04-10-2019, 04:49 PM | #6 |
04-10-2019, 06:43 PM | #7 |
Thanks for the info so far. After you unscrew the head there is a disc of some sort with a hole in the center. Anyone get that disc out w/o destroying it. I can give both a hard shake, like shaking down a thermometer, and the indicator comes out. I don't know what kind of spring, as Bill indicated, would be in there.
04-10-2019, 07:25 PM | #8 |
I just cut a slice mark on the disc and got it out, and a piece of a round gasket. down the center is a rubber liner of some sort that came apart from age. A camera shot down the middle still shows part of the liner. I think I can see a frozen/rusted up spring. I am going to soak in Evaporust over night and see what else I can take out.
04-10-2019, 10:36 PM | #9 |
I didn't want to mess with that disc since I didn't think I would be able to replace it but I'm thinking my problem might be under there also. A rebuild kit for these would be the answer but for a low dollar item I don't think that's gonna happen.
04-11-2019, 07:04 PM | #10 |
I got it apart! After soaking overnight, the order of disassembly is: unscrew the head, remove the disc with the hole in it (had to cut a slice in it w/ razor knife), with a large screwdriver back out the spring assembly, remove the "scale" cylinder. The spring was very rusty, so back into the EvapoRust.
04-11-2019, 08:52 PM | #11 |
Both ends attached to the spring unscrew. There is a thin rubber membrane capped at one end, and open toward the nozzle head. I used the end of a pencil to push it out. It was a little rotted and broke. The spring is back soaking since a few of the windings on the spring were rusted together.
04-11-2019, 09:47 PM | #12 |
Great pictures Redbird. Now I can see how the thing works. Do you have any ideas on what you might use to replace that membrane?
04-12-2019, 08:52 AM | #13 |
I got them both to work, by cutting out a disc from carb gasket material, and cut off a finger from a sterile medical glove to use as the membrane. Work very slowly while disassembling and reassembling.
04-12-2019, 09:48 AM | #14 | |
04-12-2019, 11:29 AM | #15 |
So so on accuracy!
