Old 08-10-2017, 04:00 PM   #1
The Eclector
The Eclector's Avatar
Question Installing oil Pan gaskets?
I have a 1930 Model A. I've dropped the oil pan to clean it out after blowing a head gasket. Now I want to put it back together but not having done this before, I have run up against a problem.
I have a new cork gasket set. I've removed the old rear seal and noticed that the new cork seal is about a half inch longer. It won't fit the channel without buckling. I have not soaked it in oil yet. Do I need to trim the new cork gasket or does the excess material help facilitate the seal?
Also, any sage advice for keeping the main pan seal cork in place while I'm installing it?
Steve A.
Wilmette, IL
1930 Ford Model A Speedster
1939 Ford V-8 Deluxe fordor
1946 Chevy 3600 Pickup
1948 Chevy Fleetmaster Sport Coupe with Wood Kit
1950 Studebaker Champion Starlight
1953 Dodge B4B pickup
1963 Chevrolet Corvair Spyder convertible
The Eclector is offline   Reply With Quote
Old 08-10-2017, 04:07 PM   #2
Ed H.
Default Re: Installing oil Pan gaskets?
Not sure on the crank seal I THINK you need to trim it to a tad longer and tuck the ends in, some one will chime in on that.
The cork gasket all I do is put some wheel brg grease on the block to hold the gasket up until I get the pan in place. I may be handy to cut the heads of a couple of 1/4 bolts, screw them in with fingers to use a alignment dowels.
If you see a bomb technician running, do everything in your power to keep up with him.
United States Navy
Ed H. is offline   Reply With Quote
Old 08-10-2017, 04:08 PM   #3
RawhideKid
For the model A cork gasket, cut it to 6 11/16 and soak it in water and allow it to dry in an empty tuna can.
Then read this; http://www.sacramentocapitolas.org/s...et-Article.pdf
RawhideKid is offline   Reply With Quote
Old 08-10-2017, 04:28 PM   #4
aermotor
I attach the pan gaskets to the block with spray contact cement.
John
aermotor is offline   Reply With Quote
Old 08-10-2017, 05:16 PM   #5
ModelAMike1930
ModelAMike1930's Avatar
Years ago my uncle used to tie the gaskets with cotton sewing thread. It was thin enough to get the bolts through then cut the thread and pull it out before you bring the bolts home. The thread removed with no problem.
ModelAMike1930 is offline   Reply With Quote
Old 08-10-2017, 07:11 PM   #6
Synchro909
Synchro909's Avatar
John
Or super glue.
Take care to not cut the one that goes around the bearing too short.
Old 08-10-2017, 07:20 PM   #7
1955cj5
1955cj5's Avatar
This article can give a little guidance as Rawhide mentioned..
And those studs really help with the alignment, as in the article..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-10-2017, 11:52 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Can pan gaskets REALLY be that difficult & complicated??????
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-11-2017, 01:35 AM   #9
The Eclector
Wow, that's some great advice! Thanks for the article, it seems to be just what I was looking for. It would all be a lot easier if the engine were out of the car but I'm not that lucky. Looks like I'll be fabricating some alignment studs.
Steve A.
Wilmette, IL
Old 08-11-2017, 08:29 AM   #10
V4F
V4F's Avatar
in the car installation . tack pan rails to block , fit rear cork , tack it in , if the front seal is the white one , soak or coat will oil or grease , put pan up . don't forget to hold the oil pump up also . then drive it like you stole it !
V4f
V4F is offline   Reply With Quote
Old 08-11-2017, 06:19 PM   #11
BILL WILLIAMSON
I use ONLY paper gaskets. (CORK gaskets are a PAIN in the ASS!) Glue them to the block with spray trim cement, install the rear cork at each end & in the middle, then work them in carefully. A dab of sealer, where the cork & the gasket intersect. It's EASY! Yes, the front pan bolts are testy, turning the steering helps SOME. That's what Universal Joint Sockets are made for! Just snug the bolts & you're DONE!
OH, to hold up the oil pump, just run a 1/8 pipe die down on a 3/8" SAE bolt & it'll screw in with your fingers, & just snug it up. (TIP# 19) NO, I don't have a LIST of tips, I just "make up" numbers---LOL--The Dog helps me--LOL
OH, when I pulled Vermins' pan, the pump DIDN'T fall out, "someone" had peened over the locating dowel. The oil pump drive gear had NO spring & wouldn't pull out. I don't know how "someone" secured it, so just added a spring & lett'r GO! FUN things you find inside an engine--LOL
Bill Simple
Old 08-11-2017, 10:14 PM   #12
Synchro909
Synchro909's Avatar
Bill Simple
Mine are not show cars so this won't make any difference but I cut a slot in the head of the front bolts and use a screw driver. Much easier!
Old 08-11-2017, 10:25 PM   #13
Smooth_One
Smooth_One's Avatar
I was always told your not supposed to trim any of the seals.
And make sure you remove the dipstick before reinstalling the oil pan! Mine got jammed between the pan and windage tray and I didn't know it and i almost broke the stick off.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 08-13-2017, 09:51 AM   #14
BILL WILLIAMSON
Be SURE to straighten the pan flange. I SCUFF them on the cement floor, to make sure they're straight!
Bill Unorthodox
Old 08-13-2017, 11:08 AM   #15
duke36
Similar to post 12 , for the engine pans at frame , we cut a slot in the bolt ends to help install/ remove nuts. The article in post 3 is a good method. Using minimal contact cement dabs to hold the gasket in place at a few places insures no gasket shift and allows gasket removal without a lot of residue. The gasket fronts should touch the pulley.
The plastic step ups sold by the vendors we use in our shop regularly when engine in car.
