06-26-2017, 04:28 PM | #1 |
oilpan: seal inside?
The engine rebuilder that rebuilt my B engine used a red paint on the inside of the oil pan & block. This is now coming off in spots. Apparently the red paint is some kind of electrical insulation spray paint.
I am curious if other rebuilders use a paint on the inside of the oil pan. I can understand it would protect the pan from acids created from the products of combustion. Would a rattle can epoxy paint be a good choice here? |
06-26-2017, 04:36 PM | #2 |
Re: oilpan: seal inside?
Its usually glycal paint, which is spendy, and imo a waste. So either he used the wrong kind of paint, or it wasn't properly prepped.
06-27-2017, 12:48 PM | #3 | |
GLYPTOL is an expensive reddish paint usually used to paint / SEAL the inside of block lower end. Some of expected benefits of its use this way are...sealing any very little holes/maybe cracks; prevent sludge from sticking on those painted walls and for allowing oil to return to pan more readily without using multi-grade oil. I've used it and used correctly (that is , on a CLEAN dry surface) it will stay in place and do its intended job, IMO opinion/experience. Is it necessary, your call. Model A/B blocks were/are porous iron castings, some less porous than others. If you use multi grade oil...after block is cleaned at rebuild, I say its application isn't necessary. Some MAJOR builder that I know of, use it in every block that I've seen of theirs. I've seen racer engine builders use this product to their needs. But, then that is more understandable, IMO, that warmed up engines you'd want the oil to return to pump quickly as possible. Your call. This red paint, as far as I know, is a product of industrial development/use on electrical equipment and migrated over to other uses such as engine crank cases. I would NOT attempt to use glyptol on a block that has not been thoroughly cleaned (as in tanked) nor would I use it on the oil pan. Last edited by hardtimes; 06-27-2017 at 12:53 PM. Reason: ..................... |
06-28-2017, 08:23 AM | #4 |
Special Sale: 6 rattle cans of Glyptol paint...Make an offer! Good Day! |
