Old 07-16-2017, 02:54 PM   #1
Vin-tin
Vin-tin's Avatar
Default Progress report...
...and many questions to follow as I start dissecting my coupe's body.
With the chassis mostly complete, I turned my attention to the body.
Pictured is what's left of the interior after I carefully removed the ugly vinyl someone installed.
1929 Coupe
1930 Closed Cab Pickup
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 07-16-2017, 03:00 PM   #2
Vin-tin
Vin-tin's Avatar
Default Re: Progress report...
I also removed an outer layer of grained roof material someone added.
I need to figure out what's original to the interior and roof, and how it was installed so I can make note of it for later.
1929 Coupe
Old 07-16-2017, 04:00 PM   #3
Gunmetal blue2
Gunmetal blue2's Avatar
I never worked on a coupe but your on the right track. By the way your doing a aaaaaaasome job, keep up the good work. more pics the better for fixing thing latter.
Gunmetal blue2 is offline   Reply With Quote
Old 07-16-2017, 04:34 PM   #4
d.
go super careful with removing the trim strip at the bottom of the fabric top. Yours seems to be in very good condition and this trim strip is not reproduced. proceed with caution, you have an irreplaceable unique part.
d. is offline   Reply With Quote
Old 07-16-2017, 05:35 PM   #5
Railcarmover
Railcarmover's Avatar
Looks like you are missing the two stiffener wires that run from the main bow to the header. whats your plan? harrtz canvas? Im leaning toward black on mine,course thats about two hundred years from now
Im trying to figure how to correctly preserve the ash and fill the previous tack holes in..
Railcarmover is offline   Reply With Quote
Old 07-16-2017, 05:54 PM   #6
WHN
That Sport Coupe trim strip is a real gem to still have.
Your car will be great.
Old 07-16-2017, 07:26 PM   #7
jm29henry
jm29henry's Avatar
It's going to be a great car best of luck to you please keep us updated
jm29henry is offline   Reply With Quote
Old 07-16-2017, 07:40 PM   #8
Vin-tin
Vin-tin's Avatar
Here you can see the roof layers peeled back.
Exterior black covering, layer of cotton, burlap, some type of treated fabric, and finally a stiff paper / cardboard type material.
Is all that original?
The stiff paper / cardboard type material is also sandwiched between the exterior black covering and the interior covering seen below on the sides of the roof. Near the bottom of the picture the interior cloth is missing exposing the cardboard.
Is this the way Henry did it?
1929 Coupe
Old 07-16-2017, 07:46 PM   #9
Vin-tin
Vin-tin's Avatar
Can you further explain what the wires are? (pictures, dimensions, type of material, etc.)
1929 Coupe
Old 07-16-2017, 08:11 PM   #10
Railcarmover
Check out this link,its to Lebaron Bonneys top kit for a 29 Sport Coupe,it shows the cardboard stiffeners and 'reinforcing rods' which is what I was showing you.
https://www.lebaronbonney.com/cart/comp_kits.php
the rod itself is the same diameter as the spark and throttle rods
Old 07-16-2017, 08:22 PM   #11
Railcarmover
Hell,you might have them under the top you have..
Old 07-16-2017, 09:30 PM   #12
Vin-tin
Vin-tin's Avatar
Thank you for the info.
I just checked. I do have them! They're sewn into the fabric top and look to be in excellent condition.
1929 Coupe
Old 07-16-2017, 09:50 PM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
It's fun to take a car apart & see someones' previous "handy work"!
Chief & I once did a Coupe top, using a NEW Cotton sack & coated it with that canned Roof Patching Tar, in a NO label can. Once it set awhile, we brushed it with an OLD STIFF brush & it looked like LOOOOONG GRAINED COPRA---LOL
BUT, it looked SUPER & didn't LEAK!
Bill & Chief Poor
"THE ASSISTANT GURU OF STUFF"
Old 07-17-2017, 07:32 AM   #14
Railcarmover
Its the little surprises that keep you going..good luck.
Old 07-17-2017, 02:36 PM   #15
Vin-tin
Vin-tin's Avatar
Yes it is and I love it.
I also noticed very thin flat flexible steel straps that are sewn into the fabric top. Some extend down from the support rods to above the doors. Plus a few on each side and rear of the roof. I wonder if a new top has them already sewn in, or if I have to do it? ?
1929 Coupe
Old 07-17-2017, 02:46 PM   #16
Vin-tin
Vin-tin's Avatar
One quick question. I noticed that, originally, many of the cloth covered cardboard interior panels had tacks through the cardboard, but not the cloth. How'd they do that without damaging the cloth?
1929 Coupe
Old 07-17-2017, 02:56 PM   #17
Vin-tin
Vin-tin's Avatar
How is it removed at the door jamb? It's tucked down behind the metal tab at the latch pocket. Do I carefully pry it out, or ???
1929 Coupe
Old 07-19-2017, 02:13 PM   #18
Vin-tin
Vin-tin's Avatar
Many questions, but not many answers. Everyone must be on vacation .
No problem, as i'm answering most of my own questions as i'm going along.
I figured out how to get the belt-line trim molding off. It's easy with the right tools. Took me about an hour and with no damage to the molding or the car body. The molding looks perfect. No rust, cracks, or dents.
1929 Coupe
Old 07-19-2017, 10:21 PM   #19
Synchro909
I tried to answer this a while ago but FB wouldn't allow it. I'll send a PM. Too much typing to do it all again.
My goal for 2018 is to accomplish the goals of 2017 which I should have done in 2016 because I promised them in 2015 and planned them in 2014. I don't rush.
Old 08-12-2017, 07:55 PM   #20
Vin-tin
Vin-tin's Avatar
I've been busy removing rivets. This is how she looked yesterday. She's completely apart now, down to her sub rails and cross members.
1929 Coupe
