07-07-2010, 10:50 AM | #1 |
Town Sedan body and door alignment
I am finally at the point of aligning the doors and attaching the body to the frame before I do the final painting. Yes, I have consulted Marco's write-up on doing this job and found it very useful. It is very clear how the different anchor bolds rotate the parallelogram to attain door allignment. As I remember I actually had fair alignment before I unbolted the body from the frame and did all the restoration work (that was 2 years ago). I have now started to align everything and attach the body to the frame, but now I don't know what is happening and am even to the point of frustration. And that, combined with my aching bones from getting up and down constantly has worn me out! Time to take a long coffee break (or something else) and ponder the situation. Maybe a light bulb will come on with a bit of pondering.....
Yes, quite likely I have a slightly sagging frame, but rough checks when I was doing the restoration showed less than 1/4-inch sag, but it was not a real precise measurement. I had no way of straightening the frame so was hopeful it was ok. The doors aligned fine before and even after I unbolted the body from the frame. I reattached the doors and the front was a bit high but closed and the rear was about an inch low. So I shimmed the front bolt on the cowl with up to 3 rubber washers and put one rubber shim under the pair of carriage bolts only to find the front door went up. I have been adding shims here and there and taking others away, but nothing seems to change much or else I amd getting totally confused. I am taking a two day break before I tackle this again! My plan of attack now is to remove all the shims and let the body rest on the frame. I will then check the door alignment and the space between the wood body sill and the top of the frame. I will document everything in writting before so I don't loose track of where I am and what I need to do next. Then I will shim according to Marco's procedure and hope for the best. I was just wondering if anyone else had such problems in alignment or is it just me! Suggestions and past experiences would be appreciated. |
07-07-2010, 11:49 AM | #2 |
Re: Town Sedan body and door alignment
29 Ford Guy,
I am at the same stage that you are with my 29 Town Sedan, I will be putting my body on the frame next week. Keep us informed of your issues. Thanks Ron Lawson |
07-07-2010, 12:11 PM | #3 |
Sorry I won't be much help but i'm also in about the same place as you with the body in primer and in process of block sanding but I had NOT planned to put the body on the frame for alignment before paint. I'm wondering why you had such adverse alginment issues. Did you replace wood or disassemble frame members? I set the body on saw horses and didn't touch the wood or hinges and kept main frame intact except for components. I know it will need some alignment when I drop it back on but figured I would do after paint because pulling it back off for paint would start me all over again right.
Based on your experience, maybe I underestimated this task. Bob, NJ |
07-07-2010, 01:01 PM | #4 |
Believe me, yours will probably go smoothly! I chose to do all the alignment and attaching the body to the frame before painting mainly because of the garage I am working in. I do not have the room or facilities to do a lot of this work. It is simpler for me to have it on wheels to paint. All it means is lots of masking. And then, no danger of damaging the paint job when fitting everything together. I always had a suspicion that I might have trouble at this stage. Maybe it will improve. I will keep updated, but after I ponder the problem a bit.....
07-07-2010, 06:20 PM | #5 |
Marco has a great tutorial on body alignment. I followed it and did a good job even with a slight frame sag.
LINK http://www.abarnyard.com/workshop/door-1.htm |
07-08-2010, 07:33 AM | #6 |
07-08-2010, 08:46 AM | #7 | |
How does one measure the sag of the engine mounts, Especiallly to .001? Does this mean there is a twist in the side rails of the frame? A straight edge accross the frame rails and the measure a gap? Once the sag is determined, how do you restore it to the original position? (Not a big hammer I hope ) Does the torque of the engine cause assymetrical twisting/sagging? Don't go away, I'll probably have more questions LOL Terry |
05-02-2013, 07:06 AM | #8 |
I'm curious, 29fordguy, Did you get the frame straightened and how does it fit? What methods did you use? How did it turn out?
Terry |
06-14-2013, 02:19 PM | #9 |
Hello,
I'm at the same place in my restoration as you are (body just sitting on frame with doors out of alignment) the only difference is that I have taken the radiator out so I could clean it up. I know you suppose to start the body alignment with the radiator installed and then work your way towards the back of the car, it’s going to be a couple of days before I start my frame alignment. I’m hoping you have the chance to align your doors before I start to align mine and maybe I won’t be cussing at the car so much. The car I’m restoring is a 1930 Murray Town Sedan. Cheers, Jaybo |
