03-30-2019, 05:59 AM | #21 |
Re: Tubeless Bias Tires
How we did it back in the day my fathers shop. All tires back then came tightly wrapped
with paper the beads just about pinched together. Lots of 6-00-16s 15 inch were just coming out. Remember tin quart oil cans empty of course, four cans to open the beads then put into stock room, and by the time they were sold the beads had a set. No tire machines yet all done by hand. |
04-23-2019, 07:03 PM | #22 |
I did the ether trick day before yesterday, kinda hate to admit to it here but it worked so well. Known about it for years, but I was very hesitant- partly because I have a healthcare background and partly because I'm generally a very careful guy.
But I also believe in "whatever it takes". I never use starting fluid in an engine, but I'm keeping some on hand from now on for these dam tires. |
04-24-2019, 08:11 AM | #23 |
I just mounted 4 Coker Classic wide whites. Two went on 16x4 wheels the other 2 went on 16x5. They were wrapped tightly for a while . When un wrapped the were tighter than a clams butt in a hurricane.
I mount the rim...backwards...on a car preferably a fender less one. It saves the front of the rim from scratches. cover the car ….very well ...tire irons jump around ..a lot a little soapy water on the rim and tire.... slide the tire on the rim as far as you can by hand lower the car to hold the tire in the drop center and us the irons to move the tire on usually go on pretty quick. mount other side the same way REMOVE THE TIRE VALVE.. pull the tire towards you and seat the bead on the side of the rim closest to you once it's on the bead... as best as you can get it GENTLY PUSH THE TIRE AWAY FROM YOU SO IT CONTACTS THE OPPOSITE BEAD Push too hard and it comes off the other bead ...not enough and it will let the air out have your lovely assistant open the gate valve on the compressor and allow 175 psi to rush in YOU DID PUT THE LOCKING AIR CHUCK ON RIGHT ? After you put the air chuck on wiggle ...just a little …..the tire and it should seal up and inflate Repeat for the other 3 ….took about 3 hrs to mount the 4 wheels Taking them this morning for a pro spin balance.....
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 Last edited by 32phil; 04-24-2019 at 08:13 AM. Reason: clarification |
