Old 05-30-2020, 04:43 PM   #1
slantback37
slantback37's Avatar
Default 1937 roll out crank retainer clip
What does the retainer clip look like for the 37 car. I am using mine to roll the windshield in and out, but I have to retainer clip. All I could find so far is the clip for the door handle, and they were pins in 1937. Thanks
slantback37 is offline   Reply With Quote
Old 05-30-2020, 10:48 PM   #2
bill3337
bill3337's Avatar
Default Re: 1937 roll out crank retainer clip
It's been a while since I saw mine, but think it looks like this, it holds the crank to the dash, not to the operator.
bill3337 is offline   Reply With Quote
Old 05-30-2020, 11:31 PM   #3
1937sedandelivery
Attached is a pic showing the parts involved with the regulator mechanism. Hope this helps.
gregg
1937sedandelivery is online now   Reply With Quote
Old 05-31-2020, 08:24 AM   #4
slantback37
Now to find them..
Old 05-31-2020, 10:07 AM   #5
1937sedandelivery
On one of my 37's I used a C-clip (see pdf). I wanna say it was 9/16" ID but best to measure the regulator shaft diameter to be sure. The spring washer I was able to find at Ace Hardware.
gregg
Old 05-31-2020, 10:23 AM   #6
JSeery
JSeery's Avatar
Here is 1937sedandelivery's diagram:
JSeery is online now   Reply With Quote
Old 05-31-2020, 12:41 PM   #7
slantback37
Thanks.
Old 05-31-2020, 04:50 PM   #8
slantback37
Is it the spring washer between the handle and the dash, and the stop washer under the dash??
Old 06-01-2020, 12:35 PM   #9
1937sedandelivery
I have always "assumed" that both pieces are on the backside of the dash, but now that you bring it up, I am not 100% sure. BTW, the snap ring I mentioned earlier is 11/16", not 9/16".
Sidenote: there is a chromed finish trim piece that is on the front side of the dash. The handle itself rotates on this when opening/closing the windshield. Good luck finding that piece.
gregg
Old 06-01-2020, 12:55 PM   #10
slantback37
I may already have it. I can just slide a finger nail under something there. It looks like brass though..
Old 06-01-2020, 03:42 PM   #11
JSeery
JSeery's Avatar
The photos
Old 06-01-2020, 04:39 PM   #12
1937sedandelivery
You might be right about the brass...
Old 06-02-2020, 02:22 PM   #13
slantback37
I found some make shift parts. I found a 7/8" snap ring, and a metric wave washer. I have to bore out the washer just a little to fit. I will go somewhere else to find the 11/16" snap ring.
