05-25-2020, 09:44 AM | #1 |
Distributor Shaft Sleeve
I need to re-install the Shaft Sleeves on a couple of Distributors I took apart and rebuilt. Would it be OK if I used 1/8" dia Roll Pins instead of 1/8" solid pins?
05-25-2020, 09:51 AM | #2 |
Re: Distributor Shaft Sleeve
Yes it is fine as long as it is thr right length and holds it tight.
"The more things change, the more they stay the same." |
05-25-2020, 09:56 AM | #3 |
Agreed
05-25-2020, 10:49 AM | #4 |
Sounds good to me. I believe the new sleeves you would get from the vendors come with a roll pin instead of solid as well.
05-25-2020, 12:26 PM | #5 |
