04-25-2020, 11:17 AM | #1 |
loosen brake line nuts
having heck of a time trying to break loose the brake line nuts on 50 year old system. I've rounded off 2 nuts. I heard of freezing them, torching them which is best for doing minimal damage?
04-25-2020, 12:09 PM | #2 |
Re: loosen brake line nuts
ive had to use vice grips before.these lines are dirt cheap.
04-25-2020, 01:31 PM | #3 |
Are you using 'flare nut' wrenches?
They're shaped more like a box-end wrench but with a slot in the end to slip over the brake line. They get a better grip on all 6 corners of the nut. Last edited by dmsfrr; 04-26-2020 at 03:33 PM. Reason: add photo |
04-26-2020, 01:36 PM | #4 | |
Yes, that's the number one question. I'd gone years without knowing about them, so it's worth checking if the OP is aware of them. Also, if the current brake line is a fabricated replacement (as old brake lines sometimes are) is it possible the fittings are metric? |
04-26-2020, 02:55 PM | #5 |
I replaced the old lines on my 55 last year and the driver side nut was rounded off pretty bad. I had to use vise grips to loosen the nut. After I replaced the lines,I did buy a flare nut wrench and tighten the new nuts with the flare nut wrench. Works great.
04-26-2020, 03:29 PM | #6 |
04-26-2020, 07:49 PM | #7 |
Stuff named Gibbs also works very well
04-26-2020, 07:52 PM | #8 | |
I have run across some brake fittings where the nut size seemed to be metric as no US size fit it. Had to go out and buy metric flare wrenches
04-26-2020, 08:15 PM | #9 |
Never heard of the freezing, but I did put some good heat on a front brake line once. heat travel up to the rubber line crimp and hose blew off. Had my head up in the fender and sounded like a fire cracker went off, couldn't hear for 2 days. Never did that again.
04-26-2020, 10:03 PM | #10 |
Try a 50-50 mix of acetone and atf
04-26-2020, 11:38 PM | #11 |
The relatively new flex hose between the MC and Booster in my '55 has metric fittings. The usual/standard size wrenches don't fit the nuts but metric ones do. Luckily it's not rusty or stuck.
04-29-2020, 06:02 PM | #12 |
I'd go with even a propane torch, I use Mapp gas with mine, it burns hotter. I would suggest draining and blowing out the lines before getting the blue wrench out.
05-03-2020, 07:15 PM | #13 |
bought Benzine micro torch and that did the trick. thanks all
05-04-2020, 06:42 AM | #14 |
