Old 09-16-2019, 03:22 PM   #1
Grumpy Rick
Default 292 rear main seal
I think I read somewhere that there is a way to replace the rear main seal on my '55 T-Bird without removing the motor and trans.
I know my memory is faulty, but in this case is it correct? If so, where can I read up on it?
Grumpy Rick is offline   Reply With Quote
Old 09-16-2019, 07:56 PM   #2
MplsMike
Default Re: 292 rear main seal
Here are a couple of links that might help
http://www.y-blocksforever.com/tech/...emainseal.html
http://www.eatonbalancing.com/2008/0...-y-and-others/
MplsMike is offline   Reply With Quote
Old 09-17-2019, 03:49 AM   #3
KULTULZ
KULTULZ's Avatar
Question Re: 292 rear main seal
I think the concern is can you do it 'in chassis' with a BIRD?
It is very difficult to remove the trans from a BIRD without pulling the engine/trans assembly. Is this your concern?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 09-17-2019, 05:39 AM   #4
darrell
he needs to know if the base can be removed on a t bird.i think it can but never owned one.
darrell is offline   Reply With Quote
Old 09-17-2019, 11:07 AM   #5
KULTULZ
KULTULZ's Avatar
Base?
- WHY IS IT ... -
Old 09-17-2019, 08:35 PM   #6
paul2748
paul2748's Avatar
I don't know what the "base " is. I helped a friend change the rear main seal on a 57 Tbird while the engine was still in the car. Easier with the neophrene seal. Lubing the seal before tightening up is very important.
After dropping the pan, you need to unbolt or loosen the main caps to lower the crank a little to slide the seal in the upper (block)portion. Follow the instructions about offsetting the seal
The rope seal can be done in the same manner I suppose. There is a gadget that grabs the seal so it can be pulled around the crank (don't remember the name of it).
Proper installation of the side seals is very important.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-17-2019, 09:54 PM   #7
40 Deluxe
Gadget is called a "Sneaky Pete". It was a length of small steel cable with a "Chinese finger" on one end and several "funnels" that squeezed the seal down to fit into the groove as you pulled on the seal as you rotated the crank.
I just checked online and this tool is still available. It's made by Lisle, #27000. Advanced Auto Parts and other places online.
Old 09-18-2019, 05:56 AM   #8
darrell
nobody ever heard of a base thats the thing that bolts to the bottom of the motor.sorry i dont have a picture.
Old 09-18-2019, 06:40 AM   #9
KULTULZ
KULTULZ's Avatar
Oil Pan?
- WHY IS IT ... -
Old 09-18-2019, 03:44 PM   #10
Alaska Jim
Alaska Jim's Avatar
I think he means the lower seal retainer
Alaska Jim is offline   Reply With Quote
Old 09-18-2019, 10:06 PM   #11
miker98038
miker98038's Avatar
I’ve done the rear main on my 55 bird in the car using the methods and tools above. Same with the 312 in my roadster. Read the Ted Eaton article and follow it exactly. Patience and safety glasses (for dripping oil) are your friends.
miker98038 is offline   Reply With Quote
Old 09-19-2019, 08:45 PM   #12
paul2748
paul2748's Avatar
I know that Ted Eaton had various articles on his web site. Looking at it lately I couldn't find them. What do I look under?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-20-2019, 08:00 AM   #13
darrell
i just took it for granted that people often called the oil pan base.we always used that term.
Old 09-20-2019, 02:33 PM   #14
MplsMike
A link to one of Ted’s article is in the second post above.
Old 09-25-2019, 09:45 PM   #15
Grumpy Rick
Thanks everybody. I have the car at a friends shop. He is a good mechanic, but too young to know much about Y-blocks.
I will pass the info on to him, and thanks again.
Sneaky Pete I remember hearing about, but not neoprene seals.
Rick
Old 09-25-2019, 10:34 PM   #16
zoegrant
zoegrant's Avatar
Grumpy Rick...I just finished doing the rear main seal on my 55 sedan with the engine in the car for the second time in a year. The first time I was able to slow down the leak but not stop it. This time there are no leaks or drips. If your using a neoprene seal set from NAPA the Felpro brand supplies a small plastic '' shoehorn'' in the plastic bag. After you have removed the lower seal cap and loosened all the crank bolts and if you do not have a sneaky pete or something similar you can take a fish hook with a piece of wire and put the barb thru the end of the rope seal and you can pull it out that way.
The challenging part is to get the new RUBBER seal in without peeling the back of the rubber seal as you attempt to slide it around the back of the crankshaft...here is where that plastic shoehorn comes in. Tell your mechanic that he will have to bend that sleeve to curve it to fit between the back of the seal and the block. Also, lube the seal liberally with assembly lube or grease and gently try to slide the rear seal in. Don`t rush.
What I find that worked best for me was to lube the side seals and also the sides of the engine block to make it easier to slide the seals in, then install the side seals into the cap with the ends slightly ahead of the cap,1/4" or so and those side seal tips pinched inwards so the seals start to slide in just as your pushing the cap upward. If the side seals start to bind then remove everything and start again after you have added a little more lube. If the side seals do not go completely flush to the block, no more than1/4" the installation of the side nails should push it in the rest of the way.
The nail set I received had flat or square cut tips, bevel the nails slightly, not pointed as the pointed tip can actually get stuck in the rubber of the side seal. Lube the nails liberally before installing. Tap from one side to the other in an even matter. Good luck
zoegrant is offline   Reply With Quote
Old 10-14-2019, 12:31 AM   #17
Grumpy Rick
Thanks Zoegrant. Just got back from vacation. I will forward this to my mechanic buddy.
Much appreciated.
