Old 11-16-2019, 09:48 AM   #1
Boryca
Boryca's Avatar
Default What Lube do you put in your Columbia S/W Speedo Changer?
Here's my problem: I've got a few of these Stewart Warner speedometer changers - rectifiers as I like to call them, because it seems that's what they do - and I can't figure out what type of grease should really be used in them. They chatter at high speeds, almost exclusively in OD, and do it more when cold. I'm assuming the multipurpose grease I'm using is too viscous, but it works better than some of the thinner things I've tried.
So, what do you use in your speedometer changer that keeps it quiet and healthy?
Mike
Boryca is offline   Reply With Quote
Old 11-16-2019, 10:24 AM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: What Lube do you put in your Columbia S/W Speedo Changer?
I packed mine with white lithium grease 15 years ago, and it seems to have survived OK. You might also check with John Connelly at Columbia Two Speed Parts (http://www.columbiatwospeedparts.com...peed-parts.cfm).
Are you sure the chatter isn't from the speedometer?
4dFord/SC is offline   Reply With Quote
Old 11-16-2019, 11:27 AM   #3
deuce_roadster
deuce_roadster's Avatar
I use JD cornhead grease.
Old 11-16-2019, 12:07 PM   #4
Boryca
Boryca's Avatar
And you don't notice any noise coming from it? I had tried white lithium grease initially, though I didn't pack it, and the chatter was terrible. Went to a multi-purpose, more viscous grease and it seems to chatter less, unless it's cold - warmer days don't have as much of an issue.
I'm sure it's coming from the changer, as it almost exclusively does it when in OD. For example, I can run up to 60 mph out of OD, hit the clutch, flip the switch, and once the speedometer changes, it will immediately start chattering. If I maintain speed, switch back out of OD, chatter goes away. Visually there isn't enough wear on the gear and shaft components to account for the chattering, so I'm assuming (we all know what that does) it's improper lubrication on my part.
Old 11-16-2019, 12:09 PM   #5
Boryca
Boryca's Avatar
Interesting... I just looked at JD's description, and they call it an "extra soft" grade lube. I imagine that would very much line up with the requirements of this application. I'm going to have to get some and try it out.
Old 11-16-2019, 12:22 PM   #6
G.M.
Lubriplate was what was called for the Columbia speedo parts. G.M.
Did a google search and found Lubriplate is still available
in the same silver and black 14 oz can for $11.00
www.fordcollector.com
Old 11-16-2019, 12:42 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
Make sure the speedometer cables going in and out of the Changer isn’t dry also .
Ken/Alabama is offline   Reply With Quote
Old 11-16-2019, 02:03 PM   #8
37 Coupe
37 Coupe's Avatar
I use Sil-Glyde a silicone lube from NAPA. It was first recommended to me years ago for the speedometer cable and gear changer speed adapter little gears. It ain't cheap for a tube but I won't be without it now.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 11-16-2019, 02:13 PM   #9
4dFord/SC
4dFord/SC's Avatar
Mine's never chattered.
Old 11-17-2019, 08:03 AM   #10
glennpm
glennpm's Avatar
Are you guys splitting the speedo case to add this grease?
Thanks
Old 11-17-2019, 08:13 AM   #11
4dFord/SC
4dFord/SC's Avatar
Thanks
Yes
Old 11-17-2019, 08:33 AM   #12
glennpm
glennpm's Avatar
Thanks
Thread Tools
Display Modes
