Old 12-21-2015, 01:32 AM   #1
Roadster62
Roadster62's Avatar
Default 1938 Deluxe vs 1939 Satandard Nose
If you were to park a '38 Deluxe along side a 1939 Standard and unbolt everything forward of the firewall, then swap everything back on the other, would everything fit and be the same, or are there unique parts? Long way of asking what parts are the same if I want to collect all I need for a '39 Standard nose. I've always thought that beaked hood was unique, or were there two different styles? Thanks for the help. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 12-21-2015, 02:01 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: 1938 Deluxe vs 1939 Satandard Nose
Here are comparison shots of a 1938 Ford Deluxe (Blue) and a 1939 Ford Standard (Tan). While the Grilles and Hood are the same shape, the trim is different on both. The side Panels are also a different pattern, but are the same dimensions. The front fenders are the same on both models. I hope that these pictures help answer your question.
Old 12-21-2015, 03:46 AM   #3
swoopNZ
The stainless body trim will not align from 38 deluxe to 39 standard.
The hoods while basically similar have all the trim and hood ornament holes in different places.
As you can see from the pics - the 38 deluxe trim fits in the ridge while the 39 std ( and 39 deluxe ) is about an inch or so lower.
Also the 38 deluxe trim is smooth while the 39 standard's trim has a vee like the 39 deluxe.
I have always thought that the 39 standard hood ornament and the way the stainless trim cuts back on the side panels was a styling masterpiece.
swoopNZ is online now   Reply With Quote
Old 12-21-2015, 07:16 AM   #4
ajsrodshop
does anybody have the trim for the 38 deluxe hood and center grill and cowl that's what I need for my 38 deluxe
ajsrodshop is offline   Reply With Quote
Old 12-21-2015, 09:32 PM   #5
Roadster62
Roadster62's Avatar
Thanks for the quick replies, the '38 DeLuxe is the one I like the best. Bob
Old 12-21-2015, 10:29 PM   #6
mercman from oz
To close the Hood on the 1938 Ford Deluxe models, you first have to lift the Hood to disengage the mechanism before you close it. Many uneducated people just try to pull the Hood down, which results in a bent Hood and Chrome Trim on the left hand side, as the single Support Bracket is located on the left hand side. Next time you see a 1938 Ford Deluxe, check the Hood on the left hand side for previous damage.
On the 1939 Ford Standards, Ford made a great improvement with this single bracket that was still located on the left hand side. They redesigned it so that you can just pull the Hood down to close it on the 1939 Ford Standards, a great improvement. Just remember, if you want to close the Hood on a 1938 Ford Deluxe, you must lift it first before lowering it.
Old 12-22-2015, 08:16 AM   #7
flatheadv8
flatheadv8's Avatar
Like them both, but am partial to the 39 STD for some reason.
flatheadv8 is offline   Reply With Quote
Old 12-22-2015, 08:43 AM   #8
JSeery
JSeery's Avatar
"To close the Hood on the 1938 Ford Deluxe models, you first have to lift the Hood to disengage the mechanism before you close it."
"Just remember, if you want to close the Hood on a 1938 Ford Deluxe, you must lift it first before lowering it."
Same applies to the 38 Std. Almost all 38 hoods show some damage due to this.
Old 12-22-2015, 09:35 AM   #9
Vic Piano
Vic Piano's Avatar
'37's had the same problem with the hoods... Not that it matters but, my favorite Standard front clip is the '38. Here's an interesting photo I found, it is a '38 Standard Sedan Delivery but it has a few Deluxe touches like the stainless (chrome) windshield, twin windshield wipers, etc.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 12-22-2015, 10:37 AM   #10
sidevalve8ba
sidevalve8ba's Avatar
Vic, I'm with you. I think the '38 Standard front end is beautiful. Can't really explain why, it just appeals to me.
sidevalve8ba is online now   Reply With Quote
Old 12-22-2015, 10:56 AM   #11
JSeery
JSeery's Avatar
Love all that grill!
Old 12-22-2015, 11:09 AM   #12
milo
milo's Avatar
Yes, I too like the 38 standard grille...
You're born, you die, in between you build hot rods
milo is offline   Reply With Quote
Old 12-22-2015, 03:42 PM   #13
mhsprecher
mhsprecher's Avatar
I like the 38 std grille much better, too.
I had never seen the 39 std until just recently, and this from being an old Ford guy since the mid 60's. I like it a lot, too.
mhsprecher is offline   Reply With Quote
Old 12-22-2015, 04:29 PM   #14
mercman from oz
The 1938 Ford Standards are great looking early Fords. The earlier models lacked the Chrome Trim. It is hard to believe that Old Henry redesigned the front fenders on these models, which are unique to the 38 Standard. They are completely different to any other model Ford.
Old 12-22-2015, 04:43 PM   #15
mercman from oz
Here are comparison pictures of the Early and Late production 1938 Ford Standards. That added Chrome Trim on the Grille and along the side really enhanced the look of these 1938 Ford Standards.
Old 12-22-2015, 11:53 PM   #16
Roadster62
Roadster62's Avatar
^^^^^^^^^^^^ If the '38 Standard front fenders differ from '38 Deluxe/'39 Standard what are the tell tail features to look fore? I sure don't want to buy the wrong fenders. Bob
Old 12-23-2015, 12:49 AM   #17
willowbilly3
I think it's my all time favorite.
willowbilly3 is offline   Reply With Quote
Old 12-23-2015, 07:06 AM   #18
mercman from oz
Here are some pictures of a 1938 Ford Standard front fender. You will note that they differ from the 1937 Ford fenders, as they are smooth at the top and there is crease like the 37 Fords. I hope that these photos are a help.
Old 12-23-2015, 07:15 AM   #19
mhsprecher
mhsprecher's Avatar
"It is hard to believe that Old Henry redesigned the front fenders on these models, which are unique to the 38 Standard."
Henry didn't care much for styling. He left that up to Edsel. Edsel hired Bob Gregorie to head the styling department. An inspired choice, if there ever was one.
Old 12-23-2015, 03:54 PM   #20
Roadster62
Roadster62's Avatar
Here is another question, are the two grille sections that attach to the fenders the same except for trim attachment holes? I see a bulge were the stainless fits in the bottom of the Blue car above, this area looks smooth on the tan car. Bob
Thread Tools
Display Modes
