Old 10-06-2014, 11:47 AM   #1
JackA
JackA's Avatar
Default Snyder's new brake pedal return spring
Has anyone had experiance with the new design brake pedal return spring from Snyder's?
JackA is offline   Reply With Quote
Old 10-06-2014, 12:15 PM   #2
hardtimes
hardtimes's Avatar
Default Re: Snyder's new brake pedal return spring
Hey Jack,
Yeah, I use this setup. Read the 'CROSS SHAFT' thread just above your thread now. That will give you some good info, IMO.
hardtimes is offline   Reply With Quote
Old 10-06-2014, 12:27 PM   #3
CarlG
CarlG's Avatar
Isn't that the same hook & spring set-up that they have always had?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-06-2014, 12:31 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Same one, I think might use one on my clutch, also.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-06-2014, 12:33 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Bill W.
Why?
The clutch is already plenty hard to push down.
Old 10-06-2014, 01:22 PM   #6
BILL WILLIAMSON
Originally Posted by Tom Wesenberg View Post
Why?
I know it is, Tom, But with my braces, I have to keep my left foot poised on the clutch & the extra spring "might" keep me from inadvertently keeping the T.O. bearing running!
Bill W.
Old 10-06-2014, 04:10 PM   #7
JackA
JackA's Avatar
It was a "new" item to me, and certainly was not the stock setup. I fought for half and hour and couldn't get ithooked to the motor mount, but that is just me.
Old 10-06-2014, 06:25 PM   #8
29closedcab
I had the same problem.
29closedcab is offline   Reply With Quote
Old 10-06-2014, 06:31 PM   #9
ericr
ericr's Avatar
I've had a version of it for a number of years, apparently of an earlier design, because it was not that difficult to hook the spring to the motor mount,
ericr is offline   Reply With Quote
Old 10-06-2014, 06:48 PM   #10
SteveB31
SteveB31's Avatar
Use a long screwdriver to hook the spring on the motor mount. I fought it a bit, until I got a long screwdriver and slid the spring down to the end of the screwdriver. Went on in 10 seconds.
Steve Becker
Berts Model A Center
SteveB31 is offline   Reply With Quote
Old 10-06-2014, 07:32 PM   #11
Purdy Swoft
Purdy Swoft's Avatar
It looks just like the spring setup that has been offered by many suppliers for many years but isn't original equipment. If the service brake cross shaft and brake rods are setup correct, the pedal will always return and you will have brakes that you didn't know that you had. Setup is a major part of having really good brakes .
Old 10-06-2014, 07:51 PM   #12
verrece
verrece's Avatar
I use Model A2455ACC from MACīs. It is very useful
Victor
verrece is offline   Reply With Quote
Old 10-06-2014, 11:16 PM   #13
BILL WILLIAMSON
Steve Becker
Steve, When I was young & STUPIDER, (More stupid?), I was doing a spring like a "gorilla" with my bare hands & all of a sudden I had 2 R/H THUMBNAILS Thet thing HURT for 57 DAYS!! & it's still crooked.
Bill W.
Old 10-07-2014, 06:41 AM   #14
Ron Lachniet
Ron Lachniet's Avatar
Smile Re: Snyder's new brake pedal return spring
It is easy to hook to the frame if you put a stiff S hook on the end of the spring. It may not be original but it is better than a dead battery if your pedal doesn't always return quite far enough.
Ron Lachniet is offline   Reply With Quote
Old 10-07-2014, 07:14 AM   #15
BigErn
I put one on a few weeks ago, works great. Brake light no longer stays on.
BigErn is offline   Reply With Quote
Old 10-09-2014, 05:38 PM   #16
Jwilli
Jwilli's Avatar
Put 1 on my 29 model A rat rod. Used brake spring pliers, went on easy.
Jwilli is offline   Reply With Quote
Old 10-09-2014, 07:36 PM   #17
Barber31
Barber31's Avatar
I used one and my light still stays on sometimes.
Hi Jwilli. Welcome to the Fordbarn.
Barber31 is offline   Reply With Quote
Old 10-09-2014, 07:45 PM   #18
montanafordman
montanafordman's Avatar
Better to just fix your brakes properly and get the high quality brake light switch from A&L with the brass bushings and be done with it. JMO.
Aaron in Tacoma
(although still a Montana hillbilly at heart )
montanafordman is offline   Reply With Quote
Old 10-09-2014, 08:38 PM   #19
Purdy Swoft
If the slack is taken up in all of the service brake rods and the pedal rod so that the clevis pins will just enter the brake levers and brake pedal , the pedel will rise every time on its own. I'm sure the A&L brake light switch is good, the other repro switches usually don't work right out of the box .
Old 10-09-2014, 08:45 PM   #20
Mitch//pa
the return spring is a band aide fix to compensate for other issues
Thread Tools
Display Modes
