Old 09-28-2019, 11:24 AM   #1
Redbird
Redbird's Avatar
Default Exhaust manifold torque spec
I am replacing the exhaust manifold gasket. What is the torque spec?
Redbird is offline   Reply With Quote
Old 09-28-2019, 11:41 AM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Exhaust manifold torque spec
The book says 45 ft #, but I don’t go quite that high.
Old 09-28-2019, 12:17 PM   #3
Redbird
Redbird's Avatar
Thank you!
Old 09-28-2019, 12:26 PM   #4
Werner
Werner's Avatar
If you use the brass hexa, than torque only 50 %.
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 09-28-2019, 12:43 PM   #5
Redbird
Redbird's Avatar
I used the copper ones from Bert's!
Old 09-28-2019, 01:18 PM   #6
Mulletwagon
Mulletwagon's Avatar
Easy to break a manifold. Torque progressively and evenly.
Mulletwagon is offline   Reply With Quote
Old 09-28-2019, 04:02 PM   #7
Purdy Swoft
Purdy Swoft's Avatar
I don't think that Ford listed torque specs . I only tighten model A manifolds with a three eight ratchet and a six point socket and common sense . The shorter handle on a three eights ratchet is usually a good bit shorter than a one half inch drive ratchet or pull handle and should reduce the risk of over tightening . After the engine goes through a heat and cool cycle , retighten .
Old 09-28-2019, 04:23 PM   #8
mike657894
mike657894's Avatar
ive heard 35-55. 45 is what I do. 75-100 will crack the manifold. both at one time if your real lucky.
mike657894 is offline   Reply With Quote
Old 09-28-2019, 06:17 PM   #9
Joop
Joop's Avatar
Bratton's states 25 to 30 lb
Better safe than sorry
Joop is offline   Reply With Quote
Old 09-28-2019, 06:44 PM   #10
Railcarmover
The human body is amazing,Ford mechanics were taught 'feel',torque wrenches were not used. Skills were imparted,a journeyman would guide an apprentice,much as it is today.
The human body is amazing? yes sir,once a feel for the tension on an assembly is developed,its truly amazing how the brain and body work together to duplicate the same 'feel' I've actually seen the results against a torque wrench,once you have a feel for a value repeat it a few times and test it with a torque wrench,you'll be surprised.
I've also seen great consistency between a mechanic and his air operated impact wrench..know some cats who swore by a butterfly,they could nail an assembly.Flat rate specialists,real fast operators..
Railcarmover is offline   Reply With Quote
Old 09-28-2019, 08:55 PM   #11
Johnny Nitro
Johnny Nitro's Avatar
I went to #35 with no issues. I retorque periodically.
Johnny Nitro is offline   Reply With Quote
Old 09-29-2019, 09:01 AM   #12
Purdy Swoft
Fifty five foot pounds is usually a safe torque for heads and manifolds , if you prefer to use a torque wrench .
Old 09-29-2019, 01:48 PM   #13
J Franklin
J Franklin's Avatar
25-35# is best. retorque a few times and save your manifold.
J Franklin is online now   Reply With Quote
Old 10-01-2019, 05:34 AM   #14
Big hammer
Make sure the washers are on correctly! One hand torque re torque after heat cycles.
get a bigger hammer tap done
Old 10-01-2019, 06:50 AM   #15
chap52
chap52's Avatar
X's 2
Old 10-25-2019, 03:38 PM   #16
Mad Mac
How important is it to use the correct concave manifold washers?
Mad Mac is offline   Reply With Quote
Old 10-25-2019, 04:11 PM   #17
Purdy Swoft
Most important !!!
Old 10-25-2019, 04:34 PM   #18
arnhemmer
Tight enough but not too tight, just like in the days when the car was built.
arnhemmer is offline   Reply With Quote
Old 10-25-2019, 07:00 PM   #19
Mad Mac
Originally Posted by Purdy Swoft View Post
Most important !!!
Thanks Purdy
I will get them.
Mac
