Old 06-25-2019, 01:56 AM   #1
Lawrie
Lawrie's Avatar
Default 34??steering wheel
I have in my spares a black steering wheel ,that looks very near to the 33 and 34 ones ,BUT ,it is about 1/2 inch bigger in diameter and has a thicker rim.
to fit a tapered shaft and has two keyways in it.
Any idea what year its from.
Lawrie
Old 06-25-2019, 03:16 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 34??steering wheel
Pictures please.
Old 06-26-2019, 07:27 AM   #3
Pat/Ohio
Pat/Ohio's Avatar
Without a picture, I am guessing it is perhaps a '32 replacement steering wheel. Ford changed the location of the keyway midway thru the year to relocate the top spoke to the bottom. Pat
Pat/Ohio is offline   Reply With Quote
Old 06-26-2019, 04:10 PM   #4
Lawrie
Lawrie's Avatar
Pics,it has the two keyways in it .
Lawrie
Old 06-26-2019, 04:35 PM   #5
petehoovie
petehoovie's Avatar
Is that steering wheel slightly concave?
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 06-26-2019, 04:58 PM   #6
Lawrie
Lawrie's Avatar
Yes, about the same as the 33/34 ones in my cars
Lawrie
Old 06-26-2019, 05:18 PM   #7
DavidG
DavidG's Avatar
It has all of the appearances of a normal '33-'34 wheel except for the key ways. When there are two key ways in a Ford steering wheel they are exactly opposed to one another, not side by side.
Old 06-27-2019, 10:02 AM   #8
TJ
TJ's Avatar
Lawrie, does the wheel fit a Ford tapered shaft with the key?
TJ is online now   Reply With Quote
Old 06-28-2019, 02:19 AM   #9
Lawrie
Lawrie's Avatar
Yes, It fits my 33 shaft and key
Lawrie
Old 08-31-2019, 05:49 PM   #10
Mike34
Mike34's Avatar
" When there are two key ways in a Ford steering wheel they are exactly opposed to one another, not side by side."
With all due respect, I don't agree with DavidG's sysnopsis. I am in the middle of disassembling my original '33 to rebuild the steering box. Today, I removed the steering shaft nut, and as you can see in the photo, there are two key ways and they are not opposed to one another. The key ways are about 20 degrees apart. I acquired this car in the early 1990s, it's an early '33 and it's about as original as they get. See the photo where the arrows point out the two key ways.
Regards,
-Mike
Mike34 is offline   Reply With Quote
Old 08-31-2019, 05:56 PM   #11
Lawrie
Lawrie's Avatar
Mike, I think the two keyways are so that you can either have the spoke at the top or the bottom when straight ahead, I have mine at the bottom to easily see the speedo.
I got the NOS bearings etc for the 33 box and drag link from Barnfind here on the forum.
Also dont fit the cork gasket between the sector housing and main housing, I used an O ring,
I will get back with the part number of it.
also I put a small seal where the sector shaft comes out.
Lawrie
Old 09-02-2019, 08:29 AM   #12
Mike34
Mike34's Avatar
No cork, OK. Look forward to knowing what O-rings you use. I can understand how it would seal better. Thanks.
This gearbox and a second one that I disassembled this week were both packed with grease. I'll take the forum's consensus of filling them with grease instead of oil after I rebuild them.
-Mike
Old 09-02-2019, 10:55 AM   #13
Mart
Mart's Avatar
Not grease like wheel bearing grease, John Deere cornhead grease. It's semi liquid.
Mart is online now   Reply With Quote
Old 09-03-2019, 07:31 AM   #14
JSeery
JSeery's Avatar
Originally Posted by Mike34 View Post
This gearbox and a second one that I disassembled this week were both packed with grease. I'll take the forum's consensus of filling them with grease instead of oil after I rebuild them. -Mike
As Mart posted, do not use anything like axle grease, it will not lubricate the gears surfaces properly. Cornhead grease is different, it turns to a fluid state when under a load or heat.
Old 09-04-2019, 09:15 PM   #15
Mike34
Mike34's Avatar
Got it. Cornhead grease. Thanks.
Old 09-05-2019, 04:03 PM   #16
Lawrie
Lawrie's Avatar
O rings for the sector housing are either BS-138 or BS-139
Just get them from a hydraulic shop 70 duro.
I just drove Kpars 33 with one of flathead teds boxes in ,VERY nice.
Lawrie
Old 09-05-2019, 10:02 PM   #17
G.M.
Low drip point or melt point grease works well in the old Ford
steering box's. High temperature grease will stay in place when hot
and the gear cuts a hole in the center and the gears run dry. When the
low temp grease gets warm it sags down to the bottom and the gears
pick up lubrication. They don't leak with grease if the gaskets are good.
I have used it for about 40 years. G.M.
www.fordcollector.com
