08-15-2018, 05:44 PM | #1 |
1930 Cabriolet window slide bar
Folding windshield slide bar, not window.
Can someone please tell me where the metal spring part goes? What is the right order, I just do not see this in my books. I think one end closest to the inside is just the metal washer with rubber insert and the big knurled knob on top of the slide direct to the door jamb. If that is OK then I need to know how to install the other end. It may be spring then metal slide then special little bolt that screws into the 12x24 end of the pin on the windshield. Of course I may be wrong on both. LOL. Thanks
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. Last edited by kimeccles; 08-15-2018 at 09:46 PM. |
08-15-2018, 08:44 PM | #2 |
Re: 1930 Cabriolet window slide bar
I think you meant to type windshield slide bar .
08-15-2018, 09:45 PM | #3 |
Parts catalogs may have an exploded view, showing the correct order of the parts.
Bill W.
08-15-2018, 09:47 PM | #4 |
Yes, I just need to know how it is supposed to be attached. I did not see in standards or Les book I had so far.
thanks
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. |
08-16-2018, 06:16 PM | #5 |
no spring?
08-17-2018, 08:50 AM | #6 |
08-17-2018, 09:18 AM | #7 |
I believe the spring in question is a thin washer made of spring steel.
08-17-2018, 12:14 PM | #8 |
