06-22-2019, 05:35 PM | #1 |
Seat belt length ?
For a 42-47 pickup, what length belt should a person order ?
06-22-2019, 05:37 PM | #2 |
Re: Seat belt length ?
What is your waist size?
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 06-22-2019 at 05:55 PM. |
06-22-2019, 05:51 PM | #3 |
Too many variables, (2 point, 3 point? etc.,etc and yes, waist size)
Where mounted, how mounted ?
06-22-2019, 07:29 PM | #4 |
For plain old lap seat belts here's a starter. Google provides more answers.
You could also mock up a set using rope. https://oemseatbelts.com/pages/measure-seat-belts |
06-22-2019, 07:52 PM | #5 |
Get the longest ones you can. So you MAY have a little extra, better than buying something that is too short for a rotund passenger
06-22-2019, 09:58 PM | #6 |
They work fine for both my 36" gut and my more petite wife. All in all I'm happy with them. You can if you want customize the lengths but I didn't feel the need.
Making the simple complicated for over 30 years. |
06-22-2019, 10:07 PM | #7 |
Go 3 point if you can.
06-23-2019, 06:31 AM | #8 |
Thank you everyone for the suggestions. I have a 36" waist and hope to attach through the small reinforcing plate under the cab floor behind the gas tank. I would like three point but cab is all finished inside so will settle for lap belts only.
06-23-2019, 07:53 AM | #9 |
If you install lap belts, use belts that are 3 in. wide, if possible. Use longer 74 in. belts. Consider front seat belt track travel.
https://www.seatbeltplanet.com/i-304...tegory:1389191 Below is an installation tip if you don't have a helper. The sticky tape holds the big washer in place and prevents the big washer from spinning when tightening the bolt from inside the car. Do not fasten belts to your frame and be careful not to drill holes into components under the floor pan. Last photo shows that I used two big fender washers in addition to the washers supplied. Last edited by 19Fordy; 06-26-2019 at 12:33 PM. |
