01-18-2018, 09:57 PM | #1 |
40 Pickup Fuel tank removal ?
I unfortunately think I already know the answer, but is there anyway to get the fuel tank out of a 40 pickup without removing the stock bed ?
01-18-2018, 10:45 PM | #2 |
Re: 40 Pickup Fuel tank removal ?
save time, bloody fingers, agravation and take the bed off, just six bolts and some wires, need four good friends to help or a lift of some sort
01-18-2018, 11:11 PM | #3 |
Comes out the bottom like a car.
01-19-2018, 11:55 AM | #4 |
So I got 1 take off bed, 1 out the bottom ? Which one is it ?
01-19-2018, 12:02 PM | #5 |
Both, think alan was just pointing out that in the overall scheme of things taking the bed off might be easier. But skidmarks stated you can take it out the bottom if you do not want to remove the bed.
01-19-2018, 12:22 PM | #6 |
It does work. I was surprised that it worked the first time, too, but it will. Good luck and be patient and make sure to get as much gas out first. Oh yeah, and leave your cigar on the bench!
36 Fords Rule! Visit at www.36fords.com. |
01-19-2018, 07:14 PM | #7 |
It's every bit as miserable going back in from the bottom as well.
