Old 01-15-2018, 03:11 PM   #1
1931flathead
Default transmission shaft respline
looking for some one to re spline a transmission rear out put shaft thanks
1931flathead is offline   Reply With Quote
Old 01-15-2018, 04:43 PM   #2
nick c
Default Re: transmission shaft respline
could you be a little more pacific in what your working on?
nick c is offline   Reply With Quote
Old 01-15-2018, 04:57 PM   #3
AL in NY
AL in NY's Avatar
There is a company is Indiana that can re-spline your rear output shaft. It is Moser Engineering in Portland, Indiana, 260-726-6689,
(www.moserengineering.com/Pages/Shop-ervices). You can send them a copy of the type of spline you need or tell them technically. The cost are reasonable.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-15-2018, 05:00 PM   #4
1931flathead
It is a 3+1 transmission to a flathead with in close drive shafts need to cut the shift and re spline
Old 01-15-2018, 06:33 PM   #5
MAG
MAG's Avatar
Post #3 is correct.. Had some done there. Good work. Reasonable price and turnaround.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 01-15-2018, 07:11 PM   #6
1931flathead
ok thanks
