Old 11-12-2018, 06:37 PM   #1
Gino
Default Rear leaf spring U bolt
I'm considering cutting a hole in the floor of the rumble seat to replace a bad U bolt. Any better ideas, short of lifting the body? Thanks
Gino is offline   Reply With Quote
Old 11-12-2018, 07:36 PM   #2
michael a
michael a's Avatar
Default Re: Rear leaf spring U bolt
What do you think you have to cut a hole in the floor
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 11-13-2018, 08:42 PM   #3
Gino
I hope you are going to tell me I don't have to cut the floor. Looking at it, it seems to me it is possible to remove it without lifting the body. Thanks
Old 11-14-2018, 08:07 AM   #4
Terry, NJ
Terry, NJ's Avatar
Why are you removing it in the first place? I've pulled several rears and I've never removed the bolts yet.
Terry
Terry, NJ is offline   Reply With Quote
Old 11-14-2018, 08:51 AM   #5
Dave in MN
Dave in MN's Avatar
He likely stripped the threads on the U-bolt. It happened to me but I was working on a '31 S/W Town Sedan which has a removable cover over the rear spring so it was not much work.
I suggest you go the route of lifting the body enough to replace the spring. Remove the nuts from the body bolts, raise the rear of the body...block between the body and frame for safety and make the change. Work safe.
Good Day!
Dave in MN is offline   Reply With Quote
