Old 07-15-2017, 09:33 PM   #1
PatrickTA
Default Water in cylinders. Cracked block??
Hello
So I keep getting water in the cylinders. I've replaced the head gasket 3 times and used both the copper and the modern head gaskets. And I still get a small water leak into cylinders 2 and 3. I'm not sure how this keeps happening. I've checked the head, had it decked, maged the block and the head, using grade 8 studs and nuts.
I'm beginning to think I've got a cracked block. Maybe In the valve ports? Any help would be greatly appreciated.
Thanks!
PatrickTA is offline   Reply With Quote
Old 07-15-2017, 10:39 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Water in cylinders. Cracked block??
Maybe the head, maybe not enough torque/torqued enough times. Maybe warped head or block.
Could be a lot of things.
If we knew where you lived there maybe a fordbarner near by or a local Model A club that could lend a hand.
Old 07-15-2017, 11:12 PM   #3
Railcarmover
"maged" the head and block? do you mean it was magnafluxed?
Railcarmover is offline   Reply With Quote
Old 07-15-2017, 11:25 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
That was my first thought. If the block and head were "maged", that should have shown that they were cracked or not?
Old 07-16-2017, 12:06 AM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Were they checked with a machinist level? Have you tried to pressurize either the water system ( if the radiator is connected only a few pounds of pressure) or pressurizie the cylinders involved, and watch for bubbles in the radiator? If you can borrow a block tester like shiners sells, that's a great way to test for cracks. Both clubs I belong to have one in their tool library, and I just got one for my own personal use.
Old 07-16-2017, 04:50 AM   #6
Wick
Wick's Avatar
Try another head is what I would do because your getting water in both cylinders.
Wick is offline   Reply With Quote
Old 07-16-2017, 06:04 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
If you're looking for a replacement block, I have one for you. LOL
When you buy a block at an auction, there's usually a good reason it isn't still in a car.
Old 07-16-2017, 08:02 AM   #8
jm29henry
jm29henry's Avatar
Listen to mike and wick !!! My money is on there advice
jm29henry is offline   Reply With Quote
Old 07-16-2017, 08:28 AM   #9
100IH
Yes, if the block has been in the chassis the whole time, magnaflux can miss a crack because of oil, carbon or simply lack of access. Pressure testing can be done more successfully with the above hurdles and magnaflux might actually find small hairline issues that are not yet a problem, but only if the casting has been stripped down and cleaned. Having useable babbit can be a problem when trying to use the best cleaning methods, so in your case, go bare block and with a different head.
100IH is offline   Reply With Quote
Old 07-16-2017, 08:31 AM   #10
Patrick L.
Patrick L.'s Avatar
Next time the head is off, try a torch. Just slowly wave the torch anywhere you think there could be a problem. If there is a crack that'll usually find it.
Old 07-16-2017, 08:35 AM   #11
jw hash
jw hash's Avatar
I had the same problem. my Vicky was foaming out the radiator cap on any kind of pull just enough to piss me off. I has the head milled a went to the modern gasket and it was a little better. then some of the boys told me about the head gasket that they picked up at Bert`s made by Best, I stalled one. end of problem. I have been hearing more and more of the modern gasket leaking. just my two cents
note if the are running a B head make sure you are using a B gasket.
jw hash is offline   Reply With Quote
Old 07-16-2017, 11:58 AM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Just for the HECK of it, I'd try Old Fashioned Bars-Leaks & see what happens????
Bill Guessing?
"THE ASSISTANT GURU OF STUFF"
Old 07-16-2017, 01:13 PM   #13
Railcarmover
Bill Guessing?
Or if your getting the car judged,use oatmeal and pepper for the 'period correct' repair.
Old 07-16-2017, 01:38 PM   #14
Chuck Sea/Tac
I hit a deer sliding to a stop from 80mph at night on a country road, in my dads 66 rambler wagon. It took out the radiator, so I limped two miles to the general store/post office/service station, ect and bought a large can of pepper, of which I emptied the entire contents into the radiator.As it was a big leak. Got me twenty some miles home. However the pepper also plugged the heater and it ended up being replaced as well.
Old 07-16-2017, 09:05 PM   #15
PatrickTA
So for an update and more info. It's a high compression head. older engine with a quite a bit of miles. I did magnaflux both the head and the block. I am beginning to think the block is warped or has a small crack the magnaflux couldn't see. And I torqued the head to 60-65 pounds in the proper sequence and returqued the next day.
Old 07-16-2017, 09:22 PM   #16
Railcarmover
http://diyford.com/inspect-ford-flat...ltimate-guide/
this is based on V8's but it gives you some ideas..
Old 07-17-2017, 03:27 PM   #17
Chuck Sea/Tac
So are you checking for warping???
Old 07-17-2017, 08:00 PM   #18
jax55
jax55's Avatar
Tom, looks like a lightening strike! Bad spot for a crack unless you have the skills to weld it.
jax55 is offline   Reply With Quote
