Old 02-11-2018, 02:10 PM   #1
JohnB15632
JohnB15632's Avatar
Default Accelerator Foot Rest Location
Would anyone be able to tell me the location (distance) of the accelerator foot rest in relation to the accelerator cap?
Thanks,
File Type: jpg 1931_ford_model_a_base-pic-3092557319153339850.jpg (75.1 KB, 119 views)
JohnB15632 is offline   Reply With Quote
Old 02-11-2018, 02:18 PM   #2
wrndln
Default Re: Accelerator Foot Rest Location
The footrest hole is shown next to the throttle cutout (small hole for the threaded shaft of the footrest). Steve Watrous made the nice print. Double click on the link below to see Steve's print with dimensions.
Rusty Nelson
wrndln is online now   Reply With Quote
Old 02-11-2018, 03:11 PM   #3
JohnB15632
JohnB15632's Avatar
Thank you to Rusty,
I have that drawing that you referenced. I made my upper floor board to this drawing. I inserted the hole, but had no idea why it was there.
The accelerator foot rest that I received from a parts vendor, comes with a plate that is secured to the floorboard with 3 wood screws.
The support plate also has a flat machined in it.
So, it the footrest support plate installed, centered over the hole in the floorboard?
The footrest itself is threaded to screw into the support plate and comes with a locking nut.
So, why the hole in the floorboard?
Thanks,
Old 02-11-2018, 03:17 PM   #4
WHN
Originally Posted by JohnB15632 View Post
Thank you to Rusty,
Thanks,
Engine compartment looks great. Enjoy.
Old 02-11-2018, 03:21 PM   #5
JohnB15632
JohnB15632's Avatar
Please excuse me. I uploaded the wrong photo.
The correct photo is attached this time showing the accelerator foot rest parts.
Old 02-11-2018, 03:27 PM   #6
JBill
The hole is there so the foot rest won't bottom out against the floorboard if you adjust it so that it extends way through the threaded flange.
JBill is offline   Reply With Quote
Old 02-11-2018, 03:46 PM   #7
JohnB15632
JohnB15632's Avatar
Now, that makes sense since you have said that. I just assumed that the foot rest was meant to be extended fairly high, about the height of the accelerator cap.
Much thanks!
Old 02-11-2018, 03:50 PM   #8
wrndln
JBill is correct, the hole is so the threaded part of the footrest can be lowered into the hole if desired. If you check the picture I attached above, you can see the flat part of the footrest plate faces the drivers side of the vehicle, with the threaded shaft aligned with the hole in the floorboard.
Rusty Nelson
Old 02-11-2018, 03:55 PM   #9
Big hammer
If you set the high level with the gas pedal at your cruising speed, your foot will like you on a long tour! :-)
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 02-11-2018, 03:59 PM   #10
JohnB15632
JohnB15632's Avatar
Great Help Guys!!!! Thanks so very much!!!
Old 02-11-2018, 06:28 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
WHAT FOOTREST???????? Those things are a pain in the neck & always in the way!!!!
Bill Safe
"THE ASSISTANT GURU OF STUFF"
Old 02-11-2018, 09:06 PM   #12
daren007
Bill you need smaller feet.
daren007 is offline   Reply With Quote
Old 02-12-2018, 08:25 AM   #13
art ebeling
art ebeling's Avatar
The footrest on my original 31 floor board has the flat part on the bottom and a screw tip poking thru the relief on yhe back side.
File Type: jpg 5DC66B6F-1971-473C-B679-B982FF0CF654.jpg (77.7 KB, 152 views)
File Type: jpg 3392EDA6-AB1A-46DD-B549-9F3D53A2822F.jpg (72.0 KB, 125 views)
art ebeling is offline   Reply With Quote
Old 02-12-2018, 12:23 PM   #14
100IH
That footrest was put there to avoid breaking the torgue tube and/or the rear axle banjo. First gear is low and the car can lurch forward, throwing the driver to the rear where foot comes off the gas pedal, car stops lurching, driver tromps the gas ... ... ... At one point in time the castings were beefed up because of this.
100IH is offline   Reply With Quote
Old 02-12-2018, 01:28 PM   #15
daren007
Without a footrest driving becomes uncomfortable for me.
Old 02-12-2018, 03:25 PM   #16
Russ/40
Russ/40's Avatar
I think it was a necessity for driving on those rough and bouncy roads to prevent flooring the gas on big bumps.
Old 02-12-2018, 05:33 PM   #17
California Travieso
Send a message via Yahoo to California Travieso
After not driving my car for a while, I tried to start it by pressing the foot rest! It's hard to remember wher everything is on these cars. My wife said I need a check sheet like the pilots have to start the car.
I probably need one for shutoff too, so I won't forget to turn off the key after I run the carb dry like I did the other day.
It's tough getting old.
David Serrano
California Travieso is offline   Reply With Quote
Old 02-12-2018, 05:50 PM   #18
wrndln
I have a hard time remembering the open and closed position of the gas shutoff valve. I made a little sign and hung it on the gas line next to the shutoff - problem solved, I think.
Rusty Nelson
Old 02-12-2018, 07:21 PM   #19
100IH
The gas must flow down and out to the carb -- handle points down. Off- hold back the flow -- handle crosses the downward flow.
Old 02-13-2018, 04:09 PM   #20
BILL WILLIAMSON
I "put the screws to it"---Screwed a re-po '46 Ford gas pedal to the wood floor & it rested on top of that useless button & now I can gas it, even in the DARK!---AND, I cobbled up a push button starter button, to get rid of that PESKY starter button!
Bill Modifier
