04-24-2020, 06:17 PM | #1 |
Kultulz
I sent you a PM. Thanks for any help
Paul
04-24-2020, 07:05 PM | #2 |
Re: Kultulz
PM sent.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
04-25-2020, 12:19 AM | #3 |
Re: Kultulz
Here's the text Paul. I will search for the other in the morning.
04-25-2020, 03:01 AM | #4 |
Re: Kultulz
Kultulz how far are you from Waynesburg.Pa. in miles. Or Morgantown, Wv. am 1/2 hour from Morgantown.
04-25-2020, 06:55 AM | #5 |
Re: Kultulz
I am in the EASTERN PANHANDLE of WV, just below HAGERSTOWN, MD.
04-25-2020, 08:31 AM | #6 |
Re: Kultulz
04-25-2020, 08:44 AM | #7 | |
Re: Kultulz
You need an older 4DR sedan that fits into the background. Building a tanker would follow how a police interceptor is built. ... and yes, I have drank the wine before it's time ...
04-25-2020, 08:59 AM | #8 |
Re: Kultulz
Had this 40 down to Dawsonville, Ga. at the Moonshine event a few years ago. Love to go back some time.
04-25-2020, 09:01 AM | #9 |
Re: Kultulz
In fact I got that picture on my tombstone.
04-25-2020, 09:09 AM | #10 |
Re: Kultulz
Thank You
04-25-2020, 10:06 PM | #11 |
Re: Kultulz
Forgot to say your welcome. I hoped it helped. Still working on other question.
04-26-2020, 03:32 PM | #12 |
Re: Kultulz
Paul,
I finally found my STANDARD PARTS CATALOG, but the PUB DATE (JAN 1994) is too late to find that info you need. I need a period copy. Sorry
04-26-2020, 06:37 PM | #13 |
Re: Kultulz
Here a picture of my helper. I will loan him to you if you want. He don't cost much.
04-26-2020, 07:46 PM | #14 |
Re: Kultulz
Thanks for trying. Did you happen to run across the thickness of the thrust washer you got the info on? It only had the inside and outside diameter.
04-27-2020, 01:01 AM | #15 | |
Re: Kultulz
But LARRY'S BIRD shows the tach gear drive as a roll pin and has that fancy pin for the actual DIST drive gear. So guess you were correct in your findings. EDIT - You have a 57 SHOP MANUAL for the SPECS?
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 04-27-2020 at 01:52 AM. |
Thread Tools | |
Display Modes | |
