Old 01-18-2020, 05:52 AM   #1
jrvariel48
jrvariel48's Avatar
Default T5 Bellhousing
I have a question about the Speedway/Offenhauser bellhousing.
Has anyone cut an inspection hole into their bellhousing? It would be really nice to see exactly what's going on in there and would help in finalizing adjustments.
I'd like to do it, but thought maybe it would compromise the structural integrity.
Any thoughts??
Thanks, Joe
jrvariel48 is offline   Reply With Quote
Old 01-18-2020, 11:13 AM   #2
cmbrucew
cmbrucew's Avatar
Default Re: T5 Bellhousing
Maybe drill a test hole to determine the thickness.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 01-18-2020, 01:08 PM   #3
donald1950
i used a hole saw and drilled a 1 inch hole so i could see the throw out bearing clearance, then used the silver air duct tape to seal it.
donald1950 is offline   Reply With Quote
Old 01-18-2020, 03:04 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Bruce
One can easily measure the thickness right there at the square hole for the clutch release arm. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-18-2020, 08:57 PM   #5
jrvariel48
jrvariel48's Avatar
Mine doesn't have that hole. I have the original style crossbar.
Old 01-18-2020, 08:58 PM   #6
jrvariel48
jrvariel48's Avatar
Were you able to see well enough to check clearances?
Old 01-18-2020, 08:58 PM   #7
jrvariel48
jrvariel48's Avatar
Bruce
It's pretty thick! I'd say at least a 1/4"
Old 01-18-2020, 09:05 PM   #8
JSeery
JSeery's Avatar
I drill a similar hole in the AOD bellhousing when rebuilding one to help with installation.
Old 01-18-2020, 10:46 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Well, to measure this still ain't no big trick for a show dog. Take a pair of these Vise Grip pliers and adjust 'til the two tips just barely touch both sides of the adapter's web when squeezed tight. Remove from adapter, squeeze shut again, and measure the open space between the two clamping tips...piece of cake. But yeah, it's gonna be somewhere near 1/4". DD
T5 W/TORQUE TUBE
Old 01-19-2020, 06:17 AM   #10
jrvariel48
jrvariel48's Avatar
That's an excellent idea!! I'm truly humbled by the talent and experience here on the Barn! Thank you V8!
Old 01-19-2020, 06:18 AM   #11
jrvariel48
jrvariel48's Avatar
What size did you go with?
Old 01-19-2020, 09:52 AM   #12
JSeery
JSeery's Avatar
I don't remember the exact size, I will have to check. But about 1.5 to 2 inches in diameter.
Old 01-19-2020, 11:06 AM   #13
jrvariel48
jrvariel48's Avatar
OK, I was thinking of a 2" round hole. I really don't think it'll hurt the structure at all. With the new diaphragm style clutch I'm installing, I'd really like to see what's going on in there so I can make the correct adjustments
Old 01-19-2020, 03:28 PM   #14
my4dv8
We cut a 2” hole in ours with a hole saw , cut real slow and have a solid grip on the drill. Cut very easily though . We cut the hole as when we took the clutch push rod off the fingers slipped off the release bearing, bugger. Ours was not a speedway adapter but varied from 1/2” to 3/4” thick so there is some substance to drill through.
my4dv8 is offline   Reply With Quote
Old 01-20-2020, 03:54 PM   #15
jrvariel48
jrvariel48's Avatar
Great, thanks for your input!
