12-08-2018, 01:16 AM | #1 |
Wiring help
Had a small fire today as a result of what appears to be a jammed brake light switch. Snowballed into the alternator wire and up into the terminal. Anyways i was trying to figure how how to prevent this in the future. Specifically if anyone has had luck using in-line fuses and if so what size? So far it looks like i’ll just be needing some new wires and a brake switch. Thankfully i had JUST put the fire extinguisher in the back of the car!
12-08-2018, 01:33 AM | #2 |
Re: Wiring help
I like the safety fuse that mounts on the starter. It usually has a 20 or 25 amp fuse and is a fail safe when you have a short that might burn the car up. I know some don't like it, but for about $10 it provides a way to keep the wiring from burning up the car in a dead short situation.
12-08-2018, 01:55 AM | #3 |
Re: Wiring help
And install the A&L brake light switch.
The other available switch can fail by shorting to ground! A's Always Dave |
12-08-2018, 03:26 AM | #4 | |
Re: Wiring help
I run a 30a circuit breaker for my main fuse and a 20a on the lighting circuit. |
12-08-2018, 03:26 AM | #5 |
Re: Wiring help
Duplicate post...
12-08-2018, 04:36 AM | #6 |
Re: Wiring help
12-08-2018, 10:03 AM | #7 | |
Re: Wiring help
12-08-2018, 10:43 AM | #8 | |
Re: Wiring help
I use the fuse mounted to the starter. I park our car in a cargo container and want to make sure everything is dead so I installed a battery disconnect switch. Ed |
12-08-2018, 11:14 AM | #9 |
Re: Wiring help
How are you isolating the lighting wiring from the main? Im assuming the 30a fuse is the safety fuse setup on the starter.
12-08-2018, 11:24 AM | #10 |
Re: Wiring help
12-08-2018, 01:10 PM | #11 |
Re: Wiring help
A 20A fuse at the cutout to the lighting switch and horn will open those circuits if a short occurs. The fuse mounted on the starter is intended to prevent the battery from discharging into the generator field through a shorted cutout after the engine is shut off. if either or both fuses open during operation, the ignition will still be powered from the generator.
12-08-2018, 02:39 PM | #12 |
Re: Wiring help
That is the impossible thing about understand electricity, nobody explains things the same way. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
12-08-2018, 05:50 PM | #13 | ||
Re: Wiring help
12-08-2018, 10:23 PM | #14 |
Re: Wiring help
I have 30 amp at starter and 20 amp at cut-out. Thanks Pandersen there has been some great responses.
12-09-2018, 10:12 AM | #15 |
Re: Wiring help
The Model A I purchased had a short in the headlight circuit. Burnt up low beam wiring. Replaced it and then,
I installed a fuse block and 30A Fuse at the starter. Works fine! Also double checked all wiring to make sure all was working and properly wired. |
12-09-2018, 10:32 AM | #16 |
Re: Wiring help
I always put an inline fuse in the brake lite switch because if there is a problem, it is a long way under the car to get at it on the road.
12-09-2018, 11:05 AM | #17 |
Re: Wiring help
I use a 30 amp ckt breaker on the starter and I also installed a battery cutoff switch in front of the drivers seat. I also lost my coupe to a wiring fire a couple of years ago. (You can search for pictures on a previous post ( search “ SAD DAY” ) .
12-09-2018, 11:14 AM | #18 |
Re: Wiring help
Try in search “fire”. Scroll down to “Sad day” for pictures of my totaled Coupe. 😠
12-14-2018, 04:47 PM | #19 |
Re: Wiring help
I had a couple issues with my brake light switch when I first got my coupe. You might find this thread interesting. just paste it into your search bar. it will take you to the thread.
https://www.fordbarn.com/forum/showt...e+light+switch |
12-15-2018, 12:47 PM | #20 |
Re: Wiring help
Even though all the wiring is new, I took the same approach. Plus I added a battery disconnect under the drivers seat. When I pull the car inside, I shut off the gas and throw the disconnect switch. Prior to adding the switch, I pulled the battery ground cable.
