Old 08-31-2019, 07:28 PM   #1
GaryU.
GaryU.'s Avatar
Default 1939 Ford Transmission DON'T......
DON'T LEAVE IT OUT IN THE RAIN!!! Wish I was there when this '39 transmission was removed to make sure it was put inside rather then left out in the elements for who knows how long. Found this last week locally inside a garage but when the shifter didn't move I suspected problems. Was going to pull the top anyway but was really bummed with what I found inside. Lots of corrosion and even the tower rails were frozen solid. Got the tower apart earlier this week and spent most of the day on disassembly and cleaning the rest. Was hoping to find the cluster gear intact at least because there was still gear oil inside and added pics of it to get opinions on if it could be used. Some of the other gears and the synchronizer assembly will be ok too.
GaryU. is offline   Reply With Quote
Old 08-31-2019, 08:02 PM   #2
A bones
A bones's Avatar
Default Re: 1939 Ford Transmission DON'T......
Well I for one am happy it is now in your hands. I appreciate what you do.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 08-31-2019, 08:38 PM   #3
cas3
look inside the cluster gear, thats where the bearings run. probably more important than the out side surface rust imho
Old 08-31-2019, 08:54 PM   #4
GaryU.
GaryU.'s Avatar
Inside of cluster and roller bearings had no corrosion, was concerned about the small chip pictured.
Old 09-01-2019, 02:44 AM   #5
Viv W
Clean it all up and use it. The amount of mileage most of our old cars do the gears will outlive you. In my opinion that small chip is minor and should give no problems.
Viv W is offline   Reply With Quote
Old 09-01-2019, 06:06 AM   #6
Mac VP
Mac VP's Avatar
We’ve seen worse.....much worse. I wouldn’t lose a lot of sleep over the small flaw in your cluster gear. Maybe dress the edges of it to reduce the chances of it breaking away.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 09-01-2019, 06:24 AM   #7
glennpm
glennpm's Avatar
I agree with the other comments, the chip and flaw are nothing to worry about. I would round off all the edges around both to prevent stress risers. A nice sharp and small file would do it.
Glenn
Old 09-01-2019, 08:05 AM   #8
nickthebandit
X2 to the last 2 posts.
nickthebandit is offline   Reply With Quote
Old 09-01-2019, 09:24 AM   #9
GaryU.
GaryU.'s Avatar
Thanks for the input guys. Actually bought this for another Barnmember but got his voicemail and found out later he had just bought 10 transmissions from someone and didn't need it. Since I really don't need it I've moved it to the swap meet section in case a member is looking for one.
Old 09-01-2019, 09:49 AM   #10
rotorwrench
rotorwrench's Avatar
A case with good thrust face at the rear of the counter shaft and no cracks from the front counter shaft bore are good to go.
Old 09-01-2019, 11:58 AM   #11
Clem Clement
Clem Clement's Avatar
I put ours in white vinegar for a week. helps a lot. We have 3 frozen trannys coming to Hershey. Rust is original : costs more
Clem Clement is offline   Reply With Quote
Old 09-01-2019, 12:25 PM   #12
tubman
tubman's Avatar
I'd use Evaporust on all of those parts. Vinegar will work, but it is an acid and if you forget your parts for a few days, start looking for new parts. With Evaporust, it's "set it and forget it".
tubman is online now   Reply With Quote
Old 09-01-2019, 02:52 PM   #13
Newc
Newc's Avatar
The 3" shifting fork is worth the whole job. Newc
Old 09-01-2019, 03:19 PM   #14
Ggmac
Use it
Ggmac is offline   Reply With Quote
Old 09-02-2019, 07:09 PM   #15
Talkwrench
Talkwrench's Avatar
Its what I was going to say.. People seem to pay a lot of money for these old transmissions and yet dont even look at one of the most important aspects and thats the thrust faces..
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 09-03-2019, 01:55 AM   #16
Lawrie
Lawrie's Avatar
Your right, I just spent days resurrecting a worn thrust face,some creative machining required for sure.
Lawrie
Lawrie is offline   Reply With Quote
Old 09-03-2019, 05:05 AM   #17
PeteVS
PeteVS's Avatar
I know that water in the oil corrodes the hardened steel used in the gears (transmission AND rears) like crazy!! And, since water is heavier than the oil, it goes to the bottom and gets the cluster gear really bad.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 09-03-2019, 07:28 AM   #18
JM 35 Sedan
JM 35 Sedan's Avatar
X3 on these previous posts, and I'm happy to see Mac VP chime in on this, as he had advised me on a similar situation over the phone, maybe 10+ years ago.
John
Old 09-03-2019, 07:39 AM   #19
JM 35 Sedan
Hi Clem....where are your Hershey spaces? Probably not interested in the transmissions...just want to stop and say hey
John
