Old 04-16-2019, 09:51 PM   #1
Bubsyouruncle
Default '32 V8 cast aluminum oil pan
I have a late '32 V8 cast aluminum oil pan. Without the steel swash plates pan.
Help with dimensions or photos would be appreciated.
Bubsyouruncle is offline   Reply With Quote
Old 04-17-2019, 02:24 PM   #2
BoxCar Tom
BoxCar Tom's Avatar
Default Re: '32 V8 cast aluminum oil pan
hope this helps
BoxCar Tom is offline   Reply With Quote
Old 04-17-2019, 04:57 PM   #3
DavidG
DavidG's Avatar
Tom,
Yours has been trimmed at the front. Originally they extended forward another 2"-3" to rest on that raised tab shown in your photos with beveled corners to fit the contour of the inside of the pan. Sorry, I do not have a photo.
Old 04-17-2019, 07:35 PM   #4
BoxCar Tom
BoxCar Tom's Avatar
Dave, Best pictures I have on file. That oil pan / oil tray is long gone. BTY isn't that an early version tray? I have another oil pan with tray, its remote, after your comments I should go take a look. Maybe take pics.
Old 04-17-2019, 10:36 PM   #5
DavidG
DavidG's Avatar
The oil pan and the tray in the photo are the garden variety representative of when the dipstick was relocated from the right side of the engine block to the left side of the oil pan and when a pickup tube was added to the oil pump.
The first version of the tray had no slot for the oil pump pickup tube because there was no pickup tube on the first version of the oil pump. The second version of the tray was for use with oil pans with the dipstick on the left side, but still had no slot for a oil pump pickup tube, only a small hole near the left center for the dipstick to pass through the tray. Both those two early versions of the trays are rare.
Old 04-18-2019, 03:17 PM   #6
BoxCar Tom
BoxCar Tom's Avatar
Went and took some pictures, oil tray is 15 n 7/8s long by 6 n 1/4 wide. Appears to have 4 non-stock holes punched thru down the middle. Otherwise good healthy example.
Thread Tools
Display Modes
