Old 12-25-2018, 11:51 AM   #1
philipswanson
Default 40 Wagon Scuff Plates
I was wondering if anyone with a 39-41 wagon has replaced their under door scuff plates. I see the other body styles are available so I was wondering if anyone has tried the 4 door sedan pieces. Sure they would need some trimming, but would they work on the wagon? Or
what else did you use? My originals are in bad shape and beyond repair.
philipswanson is offline   Reply With Quote
Old 12-25-2018, 04:29 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 40 Wagon Scuff Plates
I repaired all the stainless and bought new rubber for my 40 Woodie which were fairly crushed and dented. Pretty screwed up stainless can be repaired/TIG welded and polished. Could probably be made in a bead roller with some ingenuity.
Old 12-25-2018, 07:53 PM   #3
philipswanson
Where did you buy the rubber? Didn't see it in Carpenter or Drake's catalogs.
Thanks!
Old 12-26-2018, 12:15 AM   #4
40larry
I bought a beautiful new set for my 40 SW about 10 years ago. They cost $200. back them and they were worth it! They were made by a street rod shop in Portland Oregon. I will see if I can find the name and number for you. 40larry
40larry is offline   Reply With Quote
Old 12-26-2018, 08:37 AM   #5
Kube
Kube's Avatar
Keep in mind, 1939 are different than '40.
"Imagination is a crutch used by those who lack knowledge and intelligence ."
B
. Franklin
Old 12-26-2018, 10:48 AM   #6
philipswanson
How about 41? Are they the same as 40? I have seen 41 and up at C&G.
Old 12-26-2018, 11:09 AM   #7
Kube
Kube's Avatar
Nope, 40 is all by itself.
I'd think it fairly easy to modify a pair from a '40 Tudor sedan.
B
. Franklin
Old 12-26-2018, 12:02 PM   #8
philipswanson
How about a 4dr. sedan? I need all 4. I have seen them reproduced for the 4 dr. too. Are they the same cross section as the wagon ones?
Old 12-26-2018, 03:01 PM   #9
Kube
Kube's Avatar
[QUOTE=philipswanson;1709436]How about a 4dr. sedan? I need all 4. I have seen them reproduced for the 4 dr. too. Are they the same cross section as the wagon ones?[/QUOTE
The cross section is the same - the curve is not. That's why id go for the tudor - longer. I would think the longer section would be easier to modify to match the curve of your floor pan.
Perhaps someone with this particular experience might weigh in???
B
. Franklin
Old 12-26-2018, 03:09 PM   #10
40larry
Phillip:
You are getting bad information from some of these messages. The 1940 woody strips are much different from those used on the passenger cars. They attach on the side of the floor pan and are backed up by a steel strap on each of the four doors. A & M Metal Shaping made a perfect set for my car about 10 years ago. I do not know if they are still doing it but their address is 1134 N. Fremont Lane in Cornelius Oregon 97113. The phone number I have is 503-992-1998. Good luck.........40larry
Old 12-26-2018, 04:13 PM   #11
philipswanson
Thanks Larry...… I will give them a call.....
Phil
Old 12-26-2018, 04:30 PM   #12
40larry
Thanks Larry... I will give them a call.....
Phil
Oops. The phone number is 503-992-1988
sorry..........Larry
Old 12-26-2018, 04:47 PM   #13
40larry
OK. I checked and this phone number is good and he can make up a set for you as he has all the dies and tooling. By the way I got the rubber that goes with them from Bob Drake and he should still have that available....Larry
Old 12-26-2018, 05:39 PM   #14
philipswanson
Larry,
Were the ones you had made stainless or aluminum? Originals were stainless. Thanks for running down the source!
Old 12-26-2018, 06:20 PM   #15
40larry
Larry,
These are stainless exactly like the originals. When you get them they are polished and ready to install on a show quality woody.....Larry
Old 12-26-2018, 08:36 PM   #16
Kube
Kube's Avatar
Phillip:
Larry, I will "stand down" to your advice on this one. I was under the impression that the 40 wagon had a similar sill plate as the rest of the passenger cars.
I have only restored a '39 and knew that was different than a '40.
Thanks for the correction.
B
. Franklin
Old 12-26-2018, 10:00 PM   #17
philipswanson
I called them and he will call back with a price. The plates sound great! Thanks! Phil
Old 12-26-2018, 10:18 PM   #18
deuce_roadster
Like Larry said, I bought my rubber parts from Drake about 4 years ago as those were the last things I did to finish the car.
Hope you can still get them. You may have to call. Their catalog shows 81A-791980 as what would work on a 38-40 wagon. The metal (steel) strip that is on the vertical part of the sill also holds the rubber to the body on my car (which is a very late car) and seems to fit and work properly with the stainless.
Old 12-27-2018, 08:46 AM   #19
Kube
Kube's Avatar
Could you please post a photo, perhaps more than one??? It has become obvious, I have more learning to do.
B
. Franklin
Old 12-28-2018, 09:55 AM   #20
deuce_roadster
Mike, will do when I get home from visiting my son. The Drake rubber which came in a roll you cut to length, had the same profile as the brittle pieces I took off my car.
Thread Tools
Display Modes
