Old 09-22-2013, 04:32 PM   #1
Pete Fl/Wi
Pete Fl/Wi's Avatar
Default Bubba a ?
Bubba I have three of your flathead distributors that work just fine. All are on engines with the aluminum timing covers. Today I switched one to an engine with a cast iron cover. I assume that it will work fine even if the gears are not fully meshed. Should I cut off the shaft that extends beyond the gear? Thanks, Pete
Pete Fl/Wi is offline   Reply With Quote
Old 09-22-2013, 05:49 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Bubba a ?
We machine each distributor to fit the best of all the different covers.
The lower shaft is approx one half what the actual merc would be to work with all the units.
Shouldnt be a problem assuming it doesnt hit the bottom of the cover.
The lip on the housing should fit correctly as well.
The gear mesh is set to ride below the gear. So as to push upward instead of pull down when running. The gear rides a little below the center line of the cam gear.
The gear mesh is pretty loose even on the stock flathead as theres no acc drive ( like a oil pump etc) to apply torque etc...
Should run just fine........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
jimlinder@juno.com
BUBBAS IGNITION is offline   Reply With Quote
Old 09-23-2013, 10:22 AM   #3
Richard in Florida
Richard in Florida's Avatar
Originally Posted by BUBBAS IGNITION View Post
The gear mesh is set to ride below the gear so as to pull downward instead of push up when running.
Unless I'm really missing something here, seems to me the gear on the bottom of the distributor is pushed upward by the gear on the cam.
Richard in Florida is offline   Reply With Quote
Old 09-23-2013, 12:40 PM   #4
BUBBAS IGNITION
Thanks Richard,
Post ammended......somedays i actually get it right every time ...
jimlinder@juno.com
Old 09-23-2013, 03:31 PM   #5
oldford2
oldford2's Avatar
Richard,
That is a clever markup of the timing gear cover. Makes the mesh easy to understand. Thanks
John
oldford2 is offline   Reply With Quote
Old 09-23-2013, 04:20 PM   #6
Richard in Florida
Bubba, you get more stuff right more of the time than most of us could hope to do.
Old 09-23-2013, 04:22 PM   #7
Richard in Florida
Originally Posted by oldford2 View Post
Richard,
I got tired of drawing circles in the air with both hands every time I thought about that.
Thread Tools
Display Modes
