Old 09-22-2013, 09:12 AM   #1
Don
Don's Avatar
Default Dyna beads
Do the dyna beads work as good as advertised? Using 600-16 tires on a 35 roadster.can't really get the vibration out around 55 mph, thought I might try the beads.
DON P
Don is offline   Reply With Quote
Old 09-22-2013, 11:23 AM   #2
trainguy
trainguy's Avatar
Default Re: Dyna beads
I used dynamic beads in a mod A .PITA if you get a flat need special valve cores.As far as I am concerned not worth the trouble. Phil
trainguy is offline   Reply With Quote
Old 09-22-2013, 11:31 AM   #3
Cecil/WV
Cecil/WV's Avatar
They work great in commercial tires-12x22.5.
Cecil/WV is offline   Reply With Quote
Old 09-22-2013, 12:17 PM   #4
Dave C
I use dyna beads in my 67 Mustang with after market wheels that could not get balanced. Made a huge difference. Did not need special valve stems. Also use them in my car trailer tires. I am very happy with them. Dave c
Dave C is offline   Reply With Quote
Old 09-22-2013, 08:04 PM   #5
Mike B
I'll 2nd that...but add I run 10.00-22.5's
I also picked up a bag from a shop that I buy my recaps from...was surprised to find out it was a bag of powder they put in and it forms "beads/balls"...being the tightwad I am, I bought my own tires for my MotorHome and mounted them myself, then added the recommended amount for my tire size...after about 10 minutes of driving, all shakes ceased.
Mike B is offline   Reply With Quote
Old 09-23-2013, 06:05 AM   #6
Model A Bill
I see this powder/balls in the firetrucks that I work on at my regular job.Its important to check for leakage at the valve stem after checking the air pressure as the material will move towards the vale stem when air is released,causing slight leakage.The tire shops around my area reccomend adding a slight bit of air to clean the valve stem before checking.As far as the product working it does in big tires
Model A Bill is offline   Reply With Quote
Thread Tools
Display Modes
