Old 09-19-2013, 09:16 PM   #1
trainguy
trainguy's Avatar
Default Bubba,I have a question
On the adjustable vac advance,turning the allen wrench clockwise does what?
trainguy is offline   Reply With Quote
Old 09-19-2013, 09:37 PM   #2
Richard in Florida
Richard in Florida's Avatar
Default Re: Bubba,I have a question
Clockwise increases the number of degrees of advance the vacuum canister can add to the timing. The more vacuum the engine is producing at any given moment, the more of those available degrees are added.
Idle and steady cruise commonly produce the most vacuum and thus enjoy the most vacuum advance.
Obviously then, turning the wrench counterclockwise decreases the number of degrees.
Richard in Florida is offline   Reply With Quote
Old 09-19-2013, 10:44 PM   #3
Karl Wolf
Karl Wolf's Avatar
Oops- you're talking about 49-53... I was trying to figure this on a crab...
Karl
Karl Wolf is offline   Reply With Quote
Old 09-20-2013, 03:07 AM   #4
trainguy
trainguy's Avatar
Richard in Fla. Thats exactly what I wanted to know,Thanks Phil
Old 09-20-2013, 07:40 AM   #5
36tbird
Yo Richard, is there a stop on the adjustment if you turn it full counter-clockwise? In other words, if you back it all the way out does the adjustment screw come out or does it stop at the "least advanced" spot?
36tbird is offline   Reply With Quote
Old 09-20-2013, 02:20 PM   #6
Richard in Florida
There are stops but since the canisters are made in China now, the stops aren't very strong. If you reach a stop and then force it, you'll be buying a new canister soon.
Also, it's often difficult to get the cheap allen wrench go into the adjuster inside the canister. Try rounding that end of the wrench just ever so slightly.
Another also, it's much easier to make adjustments if you put pressure on the wrench to free up the mechanism inside while you turn the wrench.
Old 09-20-2013, 04:51 PM   #7
bk53
here is a pic. the skinney wrench is the one i've been trying to use since december it is the one that came with my first vacuum advance unit.
engine was out of the car for 8 months, so maybe only really trying to fiddle with this since 8/15. today I bought a new 30134 accel unit and the fat wrench is the one that works easily on both the new and the old unit. I guess I'll be returning that new one. would it be ethical to return the first wrench with the second unit?
though time will tell, I thought I crept up on the stop and yet I felt it give. Of course my timing tape fell off since I glued it on this morning. Good thing I made copies Richard.
The 276 in this runs great on mechanical advance but I don't consider it to be "tuned".
bk53 is offline   Reply With Quote
Old 09-20-2013, 06:47 PM   #8
Richard in Florida
Originally Posted by bk53 View Post
Of course my timing tape fell off since I glued it on this morning. Good thing I made copies Richard. The 276 in this runs great on mechanical advance but I don't consider it to be "tuned."
I'm delighted to hear that about your engine.
Here's my latest project. Those are old wires just being used to work out the path of each.
Old 09-21-2013, 10:52 AM   #9
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Richard has these units down pat for sure........
Thanks Richard
If it Makes Spark, we do it !!!!
www.bubbasignition.com
jimlinder@juno.com
BUBBAS IGNITION is offline   Reply With Quote
Old 09-22-2013, 07:44 PM   #10
Richard in Florida
Default Speaking of Vacuum Canisters...
Thanks Richard
Jim, do you know a source for the Motorcraft vacuum canister that was used in late '70s clockwise DuraSpark distributors?
Old 09-23-2013, 05:49 AM   #11
BUBBAS IGNITION
Default Re: Speaking of Vacuum Canisters...
I would try NAPA.........
jimlinder@juno.com
Thread Tools
Display Modes
