Old 05-09-2019, 05:38 PM   #1
vern hodgson
Default Steering column bracket
How was the steering column bracket installed? Looks as though it was soldered and riveted to the tank! So the only holes would be the four rivet holes?
vern hodgson is offline   Reply With Quote
Old 05-09-2019, 05:42 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Steering column bracket
That is correct. The solder was used to seal the plate in case of weeping. The issue I find is most of the ones that are weeping have cracks radiating out from the rivet holes where the metal is fatigued. The correct way to repair it is to weld the cracks and the holes solid and re-drill. That way the steering column is rigid again. Lots of vibrations are transferred thru the column.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-09-2019, 05:46 PM   #3
Synchro909
Synchro909's Avatar
Wouldn't welding burn off the Terne plating inside the tank and leave it vulnerable to rust? What then?
Life's journey is best undertaken slowly.
Old 05-09-2019, 06:02 PM   #4
WHN
I assume your talking about the 28/29 cars.
I would remove the tank and use a good quality slosh sealer. With the 29 we have had now for 40 years we sloshed it three times before putting it back in car. No problems for 30 years. Keeping our fingers crossed.
If you follow the directions, it should work well. Follow instructions! Enjoy.
Old 05-09-2019, 06:50 PM   #5
aermotor
However you fix the tank get rid of the column to tank bracket. Use the later model one that attaches to the dash rail. Not only does the tank to bracket flex causing the tank to crack it puts stress on the steering box to frame attachment bolts and will cause the frame to wallow out at the mount bolts. Use a little creative engineering if the later model bolt holes don't match the existing dash holes.
John
aermotor is offline   Reply With Quote
Old 05-09-2019, 06:57 PM   #6
Synchro909
Synchro909's Avatar
I've had good success by simply using a later style bracket (that mounts to the dash) to take the load off the bracket on the tank and some of that "slosh sealer". I've never welded or resoldered one not had one leak again.
BTW, RHD support brackets are not available from the vendors. I belive they were used in 1931. As far as I know, no Model As came to this country in 1931.
Old 05-10-2019, 05:32 AM   #7
monto
Mine is mounted to the dash -- no problems..
'30 Coupe
monto is offline   Reply With Quote
Old 05-10-2019, 10:31 AM   #8
Badpuppy
The dash mounting plate fits only mid-30 and later cars. Earlier tank yokes were 3/8" longer, placing the steering wheel against your pudgy thighs. This is somewhere on Steve Plucker's site, but I can't find it now -
http://www.plucks329s.org/index.htm
Badpuppy is online now   Reply With Quote
Old 05-10-2019, 11:12 AM   #9
katy
katy's Avatar
Tern
https://en.wikipedia.org/wiki/Terne
Don't go away mad, just go away.
katy is online now   Reply With Quote
Old 08-29-2019, 10:12 PM   #10
Apperloo
Apperloo's Avatar
It looks like the PO had some issues with gas weeping thru this mount area.
As a newbie I was not looking for these kind of issues when I purchased the A.
It does not leak now, at least not with a partial full tank, but it will be very likely I will be tugging on the wheel at times while cramming myself behind it.
Does anyone have a link or pic to the 31 mount installed, or even the correct parts I need to get this possible issue dealt with? A quick search shows the main part as being out of stock or discontinued on macs.........
I love a girl and "Ruby" is her name, ChaCha
Apperloo is offline   Reply With Quote
Old 08-29-2019, 11:04 PM   #11
Tudortomnz
Tudortomnz's Avatar
Ford Aust. did produce & sell Model A's in 1931 & 1932, it is just that they were 1930 models. They would have had enough inventory due to low sales that there was no need to use the '31 parts, although I believe some '31 engine numbers are recorded.
Canada did have a RHD '31 column support, it was available here in NZ. My neighbour who had a late '30 still has a spare one but not cheap [$100 NZ].
Cheers. -Tom
Tudortomnz is offline   Reply With Quote
Old 08-30-2019, 04:07 AM   #12
Mike V. Florida
Mike V. Florida's Avatar
How much original finish does one think is left before the repair?
Old 08-30-2019, 05:36 AM   #13
Steve Plucker
Steve Plucker's Avatar
Here is some information on the brackets:
http://www.plucks329s.org/pdf/gastan...31gas_tank.pdf
Pluck
www.plucks329s.org
Walla Walla (WA) Sweet A's since 1993
MARC/MAFCA member since 1978
Ford Model AA Truck Club since 1998
(LIONEL/MTH Toy Train Collector, Orange Crush Soda Collector, Steel Beer Can Collector, Old Gas Pump Collector)
Steve Plucker is online now   Reply With Quote
Old 08-31-2019, 01:30 PM   #14
Apperloo
Apperloo's Avatar
This is helping to get my head wrapped around it, but not really answering my question.
Is this 31
bracket an easy swap?
Does the older one attached to the tank get zipped off or left for strength?
Or should I just leave the original bracket as is for the purpose of keeping the truck original?
Thanks for the input.
L
Old 08-31-2019, 04:50 PM   #15
john in illinois
john in illinois's Avatar
I left the original bracket with out the rubber support and used the 31 from the dash.the lower support shoud not touch the column. Loosen steering box to align.
For 28-29 a 1/4 “ spacer is needed. There is a diagram on this somewhere,maybe someone has it.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-31-2019, 08:00 PM   #16
Railcarmover
Railcarmover's Avatar
Even back in the late 20's and early 30's lawyers controlled the corporate narrative,Ford had numerous issues in court regarding the cowl tank.from the tank screen to the steering column bracket the engineering was unsettled,forced by exposure to claim.
Railcarmover is offline   Reply With Quote
Old 09-01-2019, 11:28 AM   #17
Apperloo
Apperloo's Avatar
John
I like the idea of leaving the old bracket for originality, as long as it does not look like a leftover.
Where does the new one attach to the dash?
Old 09-01-2019, 02:42 PM   #18
Tudortomnz
Tudortomnz's Avatar
Can you provide me with specific references about any íssues in court' in this period. Most cars in this era had rear mounted tanks, just as precarious a position regarding safety as a cowl tank. Ford liked the cowl tank as it did not require a fuel pump which they would have had to pay for or the right to use the design. But it did hamper body design & by 1932 even Ford gave up on it & relegated the tank to the rear with a fuel pump.
The cowl tank was not a flaw in the design of the Model A & in fact added to the simplicity of design & long life of the car. People had been sitting on the tank in open Model T's & up to the mid '20's, motorists routinely travelled with boxes of spare fuel tied to the running boards & fenders when on long trips. Cheers.
Old 09-01-2019, 04:15 PM   #19
john in illinois
There is a rail under the dash with bolts holding parts together.
You use 2 of these bolts to hold the new column drop.
John
Welcome each day
Old 09-01-2019, 06:49 PM   #20
father-son
Just did this for a 29 Tudor. We found that an 8" long adapter gave use a little more room to drill the holes. It looks like the column support bracket is on national back order. We got ours from Steve at Berts Model A in Denver. Good luck!
father-son is offline   Reply With Quote
