Old 04-02-2019, 09:37 AM   #1
[email protected]
Default 39 shift tower, 32 case emergency brake adapter bracket
Hello all,
Does anyone make a bracket to put the stock emergency brake handle on a 32 case with a 39 shift tower? If not, I'll go to work fabricating one...
Thanks for any leads or info !
tjh6x6@aol.com is offline   Reply With Quote
Old 04-02-2019, 10:19 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 39 shift tower, 32 case emergency brake adapter bracket
Yes, I installed one for a friend a few months back. I think it came from the Early V8 Garage.
Old 04-02-2019, 12:17 PM   #3
rotorwrench
rotorwrench's Avatar
Some folks make them out of angle iron.
Old 04-02-2019, 04:30 PM   #4
Charlie Stephens
Start with the Early V8 Garage (from post #2) and if no luck try MEC, (330) 644-3450, modelengineeringco.com. I made mine with angle iron many years ago.
Charlie Stephens
Old 04-02-2019, 04:37 PM   #5
Allinger
I have also been looking for a way to mount the E-brake handle. Here are two pictures I found on the web of home made brackets to attach the handle to the newer shift housing.
Allinger is offline   Reply With Quote
Old 04-02-2019, 04:40 PM   #6
Kerk
Smile Re: 39 shift tower, 32 case emergency brake adapter bracket
Charlie, Made one many years ago and then had a request for one from my son & had it re made . May have it to copy in my shop. Will look and advise by tomorrow. Just a piece of flatstock that uses the 2 bolt holed on the tranny cover with longer bolts and 2 pieces weldedm on the flat stock for the E Brake mount. Hope the info is enough to help you. kerk
Kerk is offline   Reply With Quote
Old 04-02-2019, 04:46 PM   #7
Andy
I would use a piece of angle and weld coupling nuts on top. The 32 bosses were high.
Andy is offline   Reply With Quote
Old 04-02-2019, 05:40 PM   #8
Hoop
Hoop's Avatar
Here's the adapter kit used for mounting a V8 transmission onto a Model A. The simple angle bracket on the far right is for the e-brake ... ignore the arrow.
Easy to make.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 04-02-2019, 06:26 PM   #9
DavidG
DavidG's Avatar
All of the above seem to put the hand brake lever lower than its original position with a '32 shift lever housing which in turn requires more of a slot in the sheet metal floor plate covering the transmission for the same amount of movement of the lever. Why not install the angle iron piece with the lip up rather than down?
Old 04-02-2019, 06:44 PM   #10
Hoop
Hoop's Avatar
David, you're correct, of course. I posted the Model A kit to show that only an angle bracket was needed. Hopefully one would reference a '32 shifter top to note the correct alignment.
Maybe not.
Old 04-02-2019, 10:21 PM   #11
deuce_roadster
deuce_roadster's Avatar
The Early V8 Garage bracket is nice.
www.earlyv8garage.net/
You will also need something to route the cable to the center of the car if you want to pull equally on both rear brakes. He also makes what you need for that, and that bracket is not trivial. Both of my 32s have his bolt on brackets for the master cyl (which uses all stock holes) as well as the E brake kit. They work well and are professionally made. If you consider the time to make these properly, I believe they are a bargain. These kits can be installed and removed without harming anything stock, including the brake pedal. I would encourage you to look at his products.
Old 04-03-2019, 08:21 AM   #12
deuce5wndw
deuce5wndw's Avatar
I like the bracket from MEC.
deuce5wndw is offline   Reply With Quote
Old 04-03-2019, 08:35 AM   #13
DavidG
DavidG's Avatar
The best of the lot as that locates the lever where it would be with the original shift lever housing.
Old 04-03-2019, 03:13 PM   #14
[email protected]
Thanks to all-I contacted both sources suggested above with the following results:
Early V8 Garage has one, " custom- fabricated out of steel and TIG,d to have the same appearance and location as on the 32 trans top. $149 + $10 shipping." Available stock tbd
MEC has one in cast aluminum, made up with extra long mounting bolts, $34.00 plus shipping. Available in stock.
I ordered the MEC, David's input was helpful in getting the location as close to original.
Thanks to all folks!
Old 04-03-2019, 09:23 PM   #15
DavidG
DavidG's Avatar
Sounds cost effective too!
Old 04-03-2019, 09:58 PM   #16
cas3
i think Andy had it right, two coupling nuts ON TOP of the angle iron, done in no time.
Old 04-08-2019, 08:20 AM   #17
32phil
Has anyone had any luck contacting MEC.
I have tried for a week with no success.
An Email address or another phone# perhaps.
Thanks, Phil
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 04-08-2019, 11:31 AM   #18
Flathead Fever
Flathead Fever's Avatar
I have the MEC bracket too on my '32 Chassis with a '39 trans. Its the way to go.
Be aware that the original '32 metal trans cover that screws to the floor will not fit the '39 trans without modifying it. Its because one shiftier top leans backwards and one does not. Don't buy an original for big bucks and then have to cut it. That would be depressing! Get one of the new repros. I think they also make them with the shifter hole in the correct spot for the '39 trans.
Old 04-08-2019, 03:57 PM   #19
Hoop
Hoop's Avatar
Would you really use the MEC bracket if you doing a "period correct" installation?
(Not sure that means much to most guys.)
Old 04-09-2019, 01:37 PM   #20
[email protected]
MEC bracket arrived Monday, I ordered it by phone last Wednesday-Gene answered the phone when I first called, so suggest keep trying if you want to talk to them on that bracket. I don't have an email address or a website for them.
