Old 12-11-2014, 12:44 PM   #1
impala58
Default Front seat stands? 39 Ford deluxe Tudoor?
Howdy All
My Dads old 39 Deluxe tudoor is getting ready to go to the upholstery shop. I was looking at his seats yesterday and saw he has no rear bolt on
stands ( I guess thats what you call them?) on the back side of his stock seats that bolt through the floor.
The front one are there on both sides are they the same as the rear ones? Or are the back ones the same but a different height.
If anyone can look at there's and let me know the measurement I would greatly appreciate it. Then maybe I could fabricate a couple rear ones.
Thanks So much
Mike
impala58 is offline   Reply With Quote
Old 12-11-2014, 04:22 PM   #2
Aquaroscoe
Default Re: Front seat stands? 39 Ford deluxe Tudoor?
Any way you can post a picture?
I think my conv't and the tudoor share the same seat. My seat has rails that go between the seat frame and the feet. The rails are perpendicular to the floor and that is why I don't picture how yours are mounting at the rear. The seat feet are just right 90' angle pieces of sheet metal.
Aquaroscoe is offline   Reply With Quote
Old 12-12-2014, 11:15 AM   #3
El Rat
My 38 has four tabs that bolt to the seat one on each corner. The tabs are similiar to small pieces of angle that have square holes in the vertical section (for carriage bolts) and two round holes that are used for studs or bolts thru the floor into cage nuts.
El Rat is offline   Reply With Quote
Old 12-12-2014, 12:01 PM   #4
impala58
El Rat
That is exactly right! like his front ones anyway! Back ones are gone, are your back ones The same height as front ones?
His front one's height is 2 1/8 inchs tall length is 3 inchs
Old 12-14-2014, 01:00 PM   #5
impala58
Wow! I can't believe I stumped the forum with something
That should be as easy as measuring the height of the rear seat stands
Or feet. On the back of the front seat. Can anyone help?
better yet if someone had a rear set of seats stands or feet they could sell me I'd be interested!
Thanks
Mike
Old 12-14-2014, 06:12 PM   #6
Bubba
The front and back floor mounts are the same they each have two holes one inch apart front and back adjustment, the leg on the sliding rail the front is a little taller + they have two holes one inch apart for up and down adjustment then you have the sliding adjustment. You should be able to make two like the front and get where you wont to be. Hope this is what your looking for.
Bubba in Texas
Bubba is offline   Reply With Quote
Old 04-05-2015, 01:49 PM   #7
Herbie41
I've got a '38 deluxe 4-door. Need to find a parts picture for the seat adjust mechanism. Any ideas?
Herbie41 is offline   Reply With Quote
Old 04-05-2015, 07:20 PM   #8
swoopNZ
MEMBER EMERITUS
Take one of your front ones down to a panel or machine shop.
They should be able to make you a pair easily enough.
swoopNZ is offline   Reply With Quote
