Old 08-09-2018, 08:38 PM   #1
Cape Codder
Cape Codder's Avatar
Default Checking Spark
I have seen several times on this Forum to pull the coil wire out to check for a Spark. They usually go on to say you should have a nice blue spark approx. 1/2" long. So my question is if I don't have a strong spark should the Coill be changed or........?
Thanks for any advice or help!
Cape Codder is offline   Reply With Quote
Old 08-09-2018, 09:48 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Checking Spark
I had also read about checking the coil...
I finally got around to checking it and my old coil had a weak yellow spark barely 1/4" long..
I replaced the coil and re-tested and I had a hot blue 1/2" or greater spark...big difference.
I think it runs much better now.
I only changed the coil, everything else remained the same.
The old coil is now my spare....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 08-09-2018, 10:48 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
You need to study the BASIC, SIMPLE ignition system to UNDERSTAND HOW it works, then you can do basic, simple tests.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-09-2018, 11:59 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Toss it and buy a new good one, they are cheap. Your old one is failing and may not even get you a few miles down the road.
A bad condenser can have the same symptoms.
Old 08-10-2018, 05:08 AM   #5
old31
x2 with chuck
A few weeks a go I had the same symptoms, changed the condenser and it was fixed.
Old 08-10-2018, 09:15 AM   #6
BILL WILLIAMSON
One of our Guys has a GREAT website for learning. I "think" it's MODELABASICS.COM
Bill W.
Old 08-10-2018, 09:24 AM   #7
katy
katy's Avatar
Bill W.
Ditto
