Old 08-08-2018, 12:41 AM   #1
Mad Mac
Default 7-tooth steering bush
I recently bought a new brass upper steering bush from Snyders for reconditioning my 7-tooth steering column. This is the bush on the shaft immediately above the worm. When comparing the new repro bush with two old original ones I find that (i) it is about 3mm shorter (ii) it has a much larger oil hole and (iii) there is no spiral grove inside the bush. So is there any reason not to use this bush?
Mad Mac is offline   Reply With Quote
Old 08-08-2018, 02:32 AM   #2
denniskliesen
denniskliesen's Avatar
Default Re: 7-tooth steering bush
I would guess it will be ok and Snyder most likely uses that bushing when they rebuild a steering box. There again if you look at Bratton's photo of their online description, they show the spiral groove and smaller hole. You could always give them a call or email and ask the dimensions of their bushing. When I rebuilt mine about a year ago the length of the bushing was the same as the old and I bought it from Snyder's.
denniskliesen is offline   Reply With Quote
