09-08-2015, 09:24 AM | #1 |
Oil Pump tip
I know most of you do this but some do not so this is for them !!! When replacing the oil pan hold the pump in place by a suitable cable tie passed through the two adjacent pan bolt holes and around the back of the pump . When the pan is nearly home cut the tie and pull it clear . Some people use a bolt in the little plug hole this is not good as it is tapered and the straight bolt damages the tapered threads in the block . If you do not have a tie long enough use two as the lock end of the tie will not pass through the holes so put a short one through and use the lock end of another tie to secure it.
John in still no weather Suffolk County England . |
09-08-2015, 09:35 AM | #2 |
Re: Oil Pump tip
John,
Someone?? peened over the locating dowel on Vermin, so the pump would stay up. Bill W. in HOT-DRY California!
09-08-2015, 11:15 AM | #3 |
Re: Oil Pump tip
There are a couple versions of an oil pump retainer that makes use of the tapered threads. I have both of these.
09-08-2015, 11:42 AM | #4 | |
Re: Oil Pump tip
X2..KISS is what these devices that Carl shows tells you ! However, if caught in a 'pinch', without your favorite tool, knowing other ways to handle a task is useful ! |
09-08-2015, 11:56 AM | #5 |
Re: Oil Pump tip
In a pinch, run a 1/8" NPT die, all the way down on a 3/8" SAE bolt & it will screw in with YO' FINGERS! (CHEEP TOO!)
Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 09-08-2015 at 12:11 PM. |
09-08-2015, 03:09 PM | #6 |
Re: Oil Pump tip
John in dark evening high pressure fine weather on the way Suffolk County England . |
