Old 05-09-2013, 06:49 PM   #1
crader1104
Default Head gaskets
Why can't you use a Synder high compression head gasket on a Brumfield head?
What is different ?
crader1104 is offline   Reply With Quote
Old 05-09-2013, 06:59 PM   #2
Ron W
Ron W's Avatar
Default Re: Head gaskets
Who says you can't? Ron W
Ron W is offline   Reply With Quote
Old 05-09-2013, 07:14 PM   #3
crader1104
Synder on there web site for there head gaskets
Old 05-09-2013, 07:16 PM   #4
glenn in camino
glenn in camino's Avatar
I like the copper/fake asbestos ones. They work on any head.
glenn in camino is offline   Reply With Quote
Old 05-09-2013, 08:50 PM   #5
James Rogers
James Rogers's Avatar
What is different ?
I wouldn't use one of the modern gaskets on a lawnmower.
Old 05-09-2013, 09:17 PM   #6
Ron W
Ron W's Avatar
I used a copper one for a model B on my Brumfield Super Head. It's made by Best Co. I didn't like the one recomended by Mr. Brumfield. Ron W
Old 05-09-2013, 09:57 PM   #7
Tom Endy
Tom Endy's Avatar
A number of years ago when the modern head gaskets came on the market one was installed on my Vic with a Brumfield head. Soon after I went on a 1,000 mile tour. When I got back I went to change the oil and noticed part of the head gasket had delaminated and was sticking out about an inch under the water pump. I pulled the head and saw there were slight traces of carbon where the gasket was about to let go completely.
I have been told that these early problems have been corrected. However I have no reason to try one again when a FelPro copper gasket works just fine.
I just wish FelPro would again make the R-1 instead of just the R-3. The R-1 has a wider barrier between 1&2 and 3&4 for bores from standard to about 60 over. The R-3 is for bores of larger size.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 05-09-2013, 10:22 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Here is my guess as I'm not Mr. Brumfield. Since most times a change of head did not include a leveling of the block, he knew that if you used the recommended gasket and followed his instructions EXACTLY you would have a head that would work as advertised with no problems. If you used a gasket he did not recommend it was possible that this gasket would not allow for the non perfect block deck. I remember when he sold them he would have to post rebuttals to those that said something was wrong with his his Model A head. He would tell them offer and over to use the head gasket he recommended and each time the owner would say now it works.
