11-12-2018, 10:17 PM | #1 |
Hygrolic throwout bearing??
Has anyone ever used a hydrolic throw-out bearing . Have a T-5 behind a 59 block and this would help.
11-12-2018, 10:35 PM | #2 |
Re: Hygrolic throwout bearing??
Hey Ron, I'm sure you'll get answers here. But if you join the hamb also, you might find they will help you too and really appreciate you.
I have nothing to add besides that, as your post are always above my pay grade. Last edited by Tinker; 11-12-2018 at 10:47 PM. |
11-12-2018, 11:17 PM | #3 |
Besides my bad spelling, for some reason the guys on the Hamb don't like me. I built some bad fuel injection "Y" block and SBC back then too.
11-12-2018, 11:27 PM | #4 |
Hahaha. Most of the good guys that have info there, are here anyways. The rest can be bit of a zoo.
11-13-2018, 06:07 AM | #5 |
Simply put: I would not. They are junk made out of plastic. Even slave cylinders now
these days are plastic plus the fact both have no real feel from the pedal. And when the hydraulic / bearing fails you know what has to be done engine out or tranny out. I had a 1980s F150 6cyl. 4x4 and that was like two days of work to replace that total stupid invention... go mechanical been around since day one...I'm sorry but I just can not get a grip on so called "modern" junk programmed to fail....sam |
11-13-2018, 07:07 AM | #6 |
http://www.moderndriveline.com/catal...ulic_slave.htm
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
11-13-2018, 07:38 AM | #7 |
I thought they were used on some years of Chevy's with T-5s? I'm not sure, have one in my shop my grandson was playing around with, but we never installed it in anything. The ones I have messed around with are not plastic. I too would shy away from any OEM plastic units. There are high performance (race) units that are not overly expensive out there as well.
11-13-2018, 09:02 AM | #8 |
Ron,
I have ran a hydraulic throwout bearing in my Model A hot rod for 10-11 years , did have to replace it once due to a leaky seal but over all they work great. I bought mine from Speedy Bill and they carry the seals as well. Clutch effort is very easy and it solvedd al ot of linkage problems with a four speed , GMC six powered car....... |
11-13-2018, 09:04 AM | #9 |
The A.......
11-13-2018, 09:09 AM | #10 |
Looking over on the HAMB, there does seem to be problems with some installs. https://www.jalopyjournal.com/forum/...#post-12723870
11-13-2018, 09:50 AM | #11 | |
2) They can most certainly provide "real feel" from the pedal. An alternative would be to use the stock type throwout arm with an externally mounted slave cylinder. This would eliminate the need to pull the transmission off the engine to replace a failed cylinder, while allowing you flexibility in not having to figure out a mechanical linkage from the pedal.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
11-13-2018, 10:15 AM | #12 |
I've had a GM hydraulic clutch master cylinder and slave cylinder in my '33 Ford Coupe, with a standard thowout bearing and arm for the last 20 years with my T5. During that time I've but about 65,000 miles on it and I've loved it. I would have preferred to have a mechanical linkage, but there was no way I could make it work. This set up works well and feels good. It's easier on the knee too, if you get caught in rush hour traffic. If you are using a T5, make sure the sleeve around the input shaft is steel, not aluminum, as the aluminum can gall up and get sticky. I changed mine after that happened.
11-13-2018, 10:24 AM | #13 |
When I was building my first T5 Kits years ago I pondered what to do to activate the clutch. I decided on a hydraulic slave that bolts on the side of the trans and uses a push rod going forward to a 36 style lever. I've sold 100's of them with no problems. I was always concerned about the hydraulic brg leaking and making a mess of the clutch? At least with mine it keeps the fluid on the outside.
11-13-2018, 10:30 AM | #14 |
11-13-2018, 10:53 AM | #15 |
A $25 dollar Chev pick-up slave, a $50 '39 up Ford master, a little fabricating, and you will have a great working system; while saving $100's over the fancy aftermarket stuff that may very well not work as good or last as long anyway.
11-13-2018, 01:17 PM | #16 |
One thing to look out for on hydraulic throw-out bearings, is lack of stroke. A mechanical linkage will will generally release a lot further than the hydraulic versions. Be sure to account for this when setting one up. Everything has to be 'right'. You can't have a bunch of space between the TO bearing and clutch fingers at rest, or it won't disengage enough for clean shifts.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
11-13-2018, 01:30 PM | #17 |
Good point Mike
A friend of mine put one in an early Nova and had lots of trouble getting the travel correct. Then had a leak when piston traveled to far. He’s had the transmission out a bunch of times. I’m not a fan of that kind of trial and error but once they are setup right they can work. Like others have said if you can get away with an external slave then I think it’s a lot easier for maintenance and setup. |
11-13-2018, 03:11 PM | #18 |
Speedy Bill has it all. The Howe is the one we use and i also bought the set up tool to make the travel adjustment easier....
https://www.speedwaymotors.com/Searc...rowout+bearing |
11-13-2018, 08:14 PM | #19 |
I should explain my problem. The race engine is an 8ba block, and the street engine is a 59 series block. I've been using Toyota hydrolic master and slave cylinders. To make things easy to swap engines I decided to use a hogs head to mount the transmission. Unfortunately my slave cylinder mounting brackets mounted on the 8BA bell housing bolts. After eliminating the stupid factor. I mounted the slave cyl in a different location, so now the type engine doesn't matter. I'll try and get another video made up so you can see the progress we've made this summer. Not much, I'm afraid, everybody has had some health problems. Getting old will do that.
11-13-2018, 08:45 PM | #20 |
Looking forward to your video Ron.
