#1 |
Hi guys, I have a question.
I have fitted liners to a relieved block. What method do you use to bring the liner height down to the height of the relief? If a carbide burr, what shape works best? Thanks in advance. Mart. |
#2 |
I used a carbide burr that was ball shaped. To do it again, I would use a cylindrical burr with a ball end. With just the ball it is more difficult to control the burrs tendency to wander. Whatever burr you use, some practice on a junk part will give you the feel for controlling where the burr goes.
#3 |
I mill them at the same time as decking.
Its a fair chance that after pounding in liners you need to deck it slightly. Otherwise the tree radius shape is my favourite when it comes to carbide burrs. Donīt forget to shamfer it or getting the rings in ainīt to fun. |
#4 |
Don't folks use a router to relieve non-relieved blocks? If so, wouldn't that give you a more consistent height?
#5 |
I just use a oval shaped carbide burr for roughing and finish with a stone about 3/4" diameter that is pointed at the end for matching up the corners. And, I agree a good chamfer is important.
#6 |
Sent from my iPhone using Tapatalk |
#7 |
Allot of good information here. However, I don't feel that reliving a block does no more than reduce the compression. and very little to improve performance. Flow bench tests I run say relieving the cylinder head is more beneficial.. Unfortunately, some blocks come from the factory that way.
#8 |
#9 |
Thanks guys.
I don't have a router but have ordered some carbide burrs. The block is already relieved. Things are progressing! Mart. |
Thread Tools | |
Display Modes | |
