06-30-2017, 07:26 PM | #1 |
thread size on early Ford grease fitting
What size drill and tap size for early Ford grease fittings, 1/4 NPT?
Going to tap cap on steering box to install grease fitting so I can fill with John Deer corn head grease. 'bout done with horn repair. Should zip it up tomorrow.
06-30-2017, 07:49 PM | #2 |
Re: thread size on early Ford grease fitting
Lawson, I believe you are looking for 1/8" pipe. The tap drill for 1/8' pipe is R drill (.399). If you are looking for 1/4" pipe the drill size is 7/16".
06-30-2017, 08:14 PM | #3 |
I think you'll find the plug in a steering box is something like 5/8 NF, not a regular pipe thread.
06-30-2017, 08:48 PM | #4 |
i am going to tap the stock cap for a grease fitting.
06-30-2017, 08:51 PM | #5 |
Thanks. That's what I thought. Just looking for confirmation.
06-30-2017, 09:02 PM | #6 |
Lawson, a 11/32 drill is .005 larger than the R drill. Try it on a test piece and tap a little at a time until the grease fitting is at the desired depth. |
06-30-2017, 09:15 PM | #7 |
The original cap is only a pressed tin affair, I suspect that if you put a tap through it, there'll be insufficient threads for a grease zerk to hold. Hence, suggest you find a 5/8 bolt.
07-01-2017, 09:00 AM | #8 |
ford35, yes, you are correct, thats why I failed math, thanks!
07-01-2017, 07:57 PM | #9 |
I just use a 1 1/2" long needle grease gun tip to pump JDCH grease into the steering box. The needle allows you to get the grease into the tight spaces.
Ed "I find that the harder I work, the more luck I seem to have." - Thomas Jefferson Last edited by Capsacto; 07-03-2017 at 07:12 PM. Reason: Picture added |
Thread Tools | |
Display Modes | |
