03-10-2011, 09:04 AM | #1 |
Need Info. Swapping a 239 Flattie Ford for a 337 Lincoln
Hopefully you Flathead guys can help with this one. Thinking of a motor swap in my 49 coupe. The original 239 flattie Ford is in it now, and can get a 337 Lincoln. Any instulation info and changes that would need to be made would be apprieciated.
03-10-2011, 09:29 AM | #2 |
Re: Need Info. Swapping a 239 Flattie Ford for a 337 Lincoln
is the 337 a twelve cylinger? If so the 239 is a better engine. Back in the day we would take them out of lincolns and replace them with ford flat heads.
03-10-2011, 09:39 AM | #3 |
No it's the V8.
03-10-2011, 09:42 AM | #4 |
I think this is a bad idea.
03-10-2011, 09:43 AM | #5 |
Please explain, I'm knew to the flatheads.
03-10-2011, 09:53 AM | #6 |
I agree with old Ron. The 337 is a lot larger than the 239. It is a flat head v8 Ford truck engine. Never heard anything good about them. Pretty sure no speed parts are available. They are heavy.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
03-10-2011, 09:56 AM | #7 |
Hi oldfart36; I wouldn't do it for a number of reasons, most importantly the weight. The 337 is around three hundred pounds heavier than the 239. Then there's fit and fabrication and on and on, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain. |
03-10-2011, 09:59 AM | #8 |
03-10-2011, 10:03 AM | #9 |
I had no idea the wieght difference was that much(backing off quickly). I want to keep the car as original as possible, but give it the 50's flare. My problem is I want to use the car as a daily driver and I feel the smartest thing to do is put a remaned motor in it. Everywhere I check it seems there are 3 month waiting periods, and or brickwalls and excuses. Anybody out there know of a remaned 239 that is road ready?
03-10-2011, 10:11 AM | #10 |
A quick addition! I've been a chevy guy most of my life, but I'll be dammed before I ruin this shoebox and stick a sbc in it. There's a time and a place for everything and this is not the time and place for a SBC.
03-10-2011, 10:55 AM | #11 |
I would agree with others that have said that replacing the 239 with the 337 in a Shoe box is not the best idea. The 337 ci Truck motor replaced the V-12 in the Lincoln in '49. The Lincoln version was equipped with hydraulic lifters. In '49 Ford introduced the Lincoln Cosmopolitan as the replacement for the Continental, two models were produced, the Cosmo and the Lincoln (called the baby Lincoln by most) the "baby" was essentially a '49 Merc with Lincoln trim and the 337. I would disagree with previous posters about both the V-12 and the 337. I'm privileged to own one of each, the V-12 is in our '39 LZ Convertible Club Coup and the 337 is in our '49 Cosmo Convertible. I have enjoyed driving the '39 V-12 for the past 10 years with virtually no problems, the 337 runs very well and we are in the process of restoring the '49 Cosmo. Vic
03-10-2011, 11:11 AM | #12 |
I would think the Lincoln 337 could be installed in one of the same year model Mercury cars since they have a similar frame and the front suspention could be more easily modified to hold the weight. The 337 was one of the best of the FoMoCo flatheads but only the Lincoln cars and the F7/F8 trucks were built to take that big old block of cast iron.
I don't know of a parts supplier or engine rebuilder that keeps the 239 or 255 L-head V8s in stock on an exchange basis. It would be interesting to know though, if anybody out there does know of someone who does stock short blocks or long blocks. The possibility of the cores being cracked or rusted up is probably too great for any one to take the chance. Most of us just rebuild our own. You might find a flathead friendly machine shop in your area that could help you get yours rebuilt. Kerby |
03-10-2011, 11:25 AM | #13 |
You could call Chris at Shoebox Ford in OK at 1-800-732-6029, he often has a rebuilt flatty at the ready, good guy to deal with. ..B.
03-10-2011, 01:27 PM | #14 |
thanks, I'll try that.
03-10-2011, 01:31 PM | #15 |
Sorry Vick did not mean to hit a nerve. Grin Frank pkny
03-10-2011, 01:31 PM | #16 | |
03-10-2011, 01:43 PM | #17 |
I just remembered another one. Get in touch with Walt Dupont, he posts here, and has been building engines about as long as I've been alive. He has a great reputation and when I was up to visit him last October he was putting together an 8BA just to have around for when someone like you called. Craig.
03-10-2011, 02:02 PM | #18 | |
This also increases the wheelbase to 121" as opposed to the Mercury's 118". |
03-10-2011, 02:37 PM | #19 |
Boy! We do learn alott on this forum.
03-10-2011, 02:41 PM | #20 |
No problem Frank, LOL You know I love my Flatheads! Vic
03-10-2011, 02:55 PM | #21 |
03-10-2011, 02:56 PM | #22 |
If you go with the big block flathead 337 you will only have to lower the back for that 50's lowrider look!
03-10-2011, 04:25 PM | #23 |
03-10-2011, 06:16 PM | #24 | |
