Old 07-02-2012, 08:24 PM   #1
Phred
Phred's Avatar
Default TECH: Distributor Shim
Its not unlikely that over the last eighty years our engine blocks and cylinder heads have been milled to the point that the distributor now rides too high above the top of the cylinder head and "wobbles" as it turns, or the distributor set screw in the engine block does not line up with the groove in the distributor collar the sets down into the cylinder head.
In the past I have spent too much time grinding down the distributor shafts, filing the groove at the end of the shaft deeper, and/or filing down the tang at the end of the distributor.
A simpler solution is to shim the gap between the distributor and cylinder head with valve spring shims. The VSI 103 shim (small block Ford V8) is just the right size (OD: 1 1/2", ID: 1 1/32") and is available in .015", .030", and .060" thicknesses.
While this seems like an epiphany and has worked for me, I will not take any credit for the idea as I am sure others have come up with this idea before I did.
I thought this might be something good to file away in the back of your minds or in your tech sheets
Peace to all.
Phred is offline   Reply With Quote
Old 07-02-2012, 09:44 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: TECH: Distributor Shim
Never thought of that but you are correct in that it would happen.
Old 07-03-2012, 07:04 AM   #3
john in illinois
john in illinois's Avatar
That is a good idea. Another tip that I just found. I had my distributor off and noticed the locating pin was a sloppy fit in the head. you could turn the distributor back and forth when mounted.
I turned a new pin for a snug fit in the head. The distributor sits there like a rock now. No need to over tighten the screw.
John
john in illinois is offline   Reply With Quote
Old 07-03-2012, 07:36 AM   #4
Bruce
Bruce's Avatar
Your new way may be easier, Phred, but the old filing/grinding way is better. It lowers the car's center of gravity.
Bruce is offline   Reply With Quote
Old 07-03-2012, 08:04 AM   #5
Doug in NJ
Doug in NJ's Avatar
So, when this situation occurs, what is actually holding up the distributor? Could there be an unwanted end thrust on the shaft that could wear out the sleeve or fiber washer at the bottom of the distributor? And could the distributor drive gear get pushed downwards and suffer?
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 07-03-2012, 12:22 PM   #6
d.j. moordigian
d.j. moordigian's Avatar
Too add to Doug's response.....
The "new" shaft/shafts could be bit long?
d.j. moordigian is offline   Reply With Quote
Thread Tools
Display Modes
