Old 09-26-2018, 11:40 AM   #1
draggin49
Default Anyone using a powermaster generator ?
I was looking into buying one of these to help handle the addition of halogen lights and some other items . When I looked at powermasters list of generator by years I noticed they do not show one for 1932 ,
It shows them offering one for 1939-1948.
Would I be able to use that on a 1932 or are they not interchangeable?
I’m trying to stay away from using a regular alternator due to the look I’m going for .
draggin49 is offline   Reply With Quote
Old 09-26-2018, 12:04 PM   #2
JSeery
JSeery's Avatar
Default Re: Anyone using a powermaster generator ?
It is a bit more expensive, but Whitney rebuilds your original generator into an alternator. I really like the look myself.
http://www.ejwhitneyco.com/automotive.html
Old 09-26-2018, 12:17 PM   #3
draggin49
Jseery, yeah those are very nice . What is the rating on the stock 32 generators originally?
Old 09-26-2018, 12:28 PM   #4
Charlie Stephens
The original generator mounted on a post. Are you using the original intake manifold? If it was me I would just get a later 2 brush generator and have it rebuilt. I would assume you could get by with the original generator, what are your "other items", an electric heater? How many amps do the halogen lights use, what about LED's?
Charlie Stephens
Old 09-26-2018, 01:25 PM   #5
draggin49
Pics
File Type: jpg D7CB251F-F1D8-4DA8-9E02-F427DF821B78.jpg (59.7 KB, 92 views)
File Type: jpg 0EA15D2C-D258-4E9C-AC3F-70E183FC29E5.jpg (38.4 KB, 73 views)
Old 09-26-2018, 01:26 PM   #6
draggin49
I can’t recall what year but the previous owner told me it was running a later year (not 1932) intake manifold
Old 09-26-2018, 01:40 PM   #7
flatheadmurre
flatheadmurre's Avatar
If you buy a regulator for it instead of the diode there now it´s a step up...just saying...
The charging now is regulated by moving the third brush and very few wants to go out under the hood and start wrenching when you want to turn the headlights on...
Old 09-26-2018, 02:59 PM   #8
Ken/Alabama
Ken/Alabama's Avatar
Can the Powermaster stand the stress of the fan being mounted to the front of it? Didnt know if that front bearing would handle the thrust.
Ken/Alabama is offline   Reply With Quote
Old 09-26-2018, 03:02 PM   #9
Flathead Fever
Flathead Fever's Avatar
While were on the subject, has any one used one of these with a original generator mounted fan? I've talked to a couple of the people building these alternators that told me I could not run a fan on one. I'm not sure why, are the bearings too small?
Flathead Fever is offline   Reply With Quote
Old 09-26-2018, 03:22 PM   #10
JSeery
JSeery's Avatar
The unit I posted (Whitney) uses the original front and rear endplates. Have you talked to Whitney? You have to send them your generator to be modified.
Old 09-27-2018, 10:47 AM   #11
hotrodA
hotrodA's Avatar
I have one (12V) on the 59AB in my 32.
I wanted 12V, and actually have a converted early Ford generator, but wanted the simplified wiring from the Powermaster. I used a Speedway wide belt fan adapter and stock Ford fan. I only have about 250 miles on it, but so far no problems. PM says no problem using it as is.
hotrodA is offline   Reply With Quote
Old 09-27-2018, 11:20 AM   #12
john in illinois
john in illinois's Avatar
I always thought there was a reason that the Powermaster is not listed for use on any early engines with generator fans even though it would fit. I went with a Whitney alternator with Ford bearings meant to support the thrust from a fan.
John
john in illinois is offline   Reply With Quote
Old 09-27-2018, 12:03 PM   #13
aussiesteve
I wouldn,t use a powermaster generator as a wheel chock,let alone run it on my car.
I did once and learnt an expensive lesson
aussiesteve is offline   Reply With Quote
Old 09-27-2018, 02:43 PM   #14
my4dv8
Aussiesteve ,Why ? very expensive wheel chock. We have done near 20000 miles on two of them with no issues. But no fan mounted on them either. Using an 8BA style fan mount .
my4dv8 is offline   Reply With Quote
Old 09-27-2018, 06:19 PM   #15
Brendan
Brendan's Avatar
i have a friend that put one on a 35 pickup, it took out the radiator
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 09-27-2018, 06:26 PM   #16
Brendan
Brendan's Avatar
anouther Friend of mine had a GM alternator with a Speedway pulley to run a fan on a 36 pickup. we went for a maiden voyage, with a fresh 59 A motor, when we got to 50 mph there was a bad vibration.we drove home, the first thing i did was drop the fan belt vibration gone. then took off the fan, and that was it. i think the GM alternators or the Power master can't handle a fan...
Old 09-27-2018, 11:08 PM   #17
TomT/Williamsburg
TomT/Williamsburg's Avatar
I have a 12 volt Powermaster unit from Speedway on my avatar - 7+ years, 50k + miles, and at sustained speeds between 65-85 mph, still running just fine ......
My fan runs up front if the generator off of a fan hub on a separate pulley
TomT/Williamsburg is offline   Reply With Quote
Old 09-28-2018, 09:04 AM   #18
itslow
itslow's Avatar
Powermaster specifically states to not use their product on an installation with a generator mounted fan. I suspect the bearings and shaft are not sized for the additional stress imparted by the fan.
The EJ Whitney units would be a different matter, since they are using the original generators as cores for conversion. One would need to consult with them regarding fan mounting.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 09-28-2018, 12:16 PM   #19
Dave/Green Bay
Luke: Is this going on your hot rod that you are working to put the McCulloch on? If so the generator mounts behind the supercharger and the fan is not an issue.
Dave/Green Bay is offline   Reply With Quote
Thread Tools
Display Modes
